Damper Plate |
Post Reply | Page <12 |
Author | ||
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10643 |
No automotive application Since you're not the original poster just to avoid confusion, he (schultz227) has a PCM transmission that takes a plate only available from PCM and you (nitro scott) can use an aftermarket plate with your Borg Warner transmission. Search here on CCF for damper plate and you'll get plenty of results. Or start your own thread to avoid confusion |
schultz227
Groupie Joined: August-20-2019 Location: Indiana Status: Offline Points: 49 |
He’s saying we can put a harmonic balancer on the front ? I have no clue and if he’s trying to cut corners I want to know
Kyle, The harmonic balancer and damper plate are two separate items. |
Well, since you asked...................Yes, he's trying to cut corners He got you the wrong flywheel, which you may not need to begin with if only the teeth on the ring gear are chewed up because of your starter issue like mentioned above. He's trying to avoid the time spent pulling the transmission and bellhousing again to replace the mistake and then the reassembly takes time again too. Basically trying to avoid doing the job over His way will be a pretty much guaranteed nightmare |
schultz227
He ordered from the parts store ,67 mustang 289 with 4 speed and he says no guarantees.. I hope this is the correct one .
schultz227
I have the 123:1 tranny Not borg Warner just FYI
It'll work But..............what's wrong with the old flywheel itself? Not the ring gear, the flywheel |
Same flywheel and ring gear but uses a different damper plate than the Borg Warner. If you had the wrong damper plate you couldn't put the thing back together |
That's where I was going when I asked what was wrong with the original flywheel when I asked in the second post. But I never got an answer. This guy is a clueless part changer. Is it too much to ask where did he order the second flywheel and it's part number since he confused and now offers no guarantees?
Quit sugar coating it Gary, say what you really think |
schultz227
Pioneer 157 tooth W163 that’s ordered from oreilly
It'll work |
Could not find it on O'Reilly but Summit did have it's spec's
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
Thanks(1)
You’re not wrong... but to add to the confusion, the current PCM 1.23 (80a) uses the same damper as the BW. There may be some family ties in the cc/Pcm/velvet drive family. The legacy pcm 1.23 (40a) that ZF built is the one with the different damper. Like ken alluded to, you cannot undo an improper flywheel balance by changing the harmonic balancer on the front of the engine. BOTH need to match the balance of the engine’s rotating assembly. |
No sugar coating, he's a backyard hack! Kyle, Where did you find this "mechanic"? |
I did some learnin' today. Thanks for that info TRB |
I'm still wondering what happened to the original flywheel
schultz227
He’s got it , I’ve suggested taking the new ring gear and putting it on the old flywheel but he says it has to go to another shop of some sort to swap it and I’ll have more money in that or some bull ****
gun-driver
https://www.summitracing.com/parts/atp-za503
He doesn't have a torch to heat the gear? That's all it takes!
Geez. Have done that swap on the dock with a little map torch.
Being naturally a little on the cheap side, I'd return both the flywheel that wasn't right and the new one that he just ordered and just get a new 157 tooth ring gear for 20 to 25 bucks or so.(with tax)
Same application 67 Mustang with a 289 and a 4 speed (some parts listings don't have the right number but an ATP ZA 503 or Pioneer FRG 157N are two good numbers to use or cross reference) Then put it on the old original flywheel. If your mechanic hasn't replaced a ring gear before, it'll be a good learning experience for you and him |
Fire the old BBQ and throw it in there for 5min a side
schultz227
UPDATE Put the new ring gear on the old flywheel, runs great.. new damper plate also.. wasted a lot of time as he had to do the job twice.. so glad I was insistent on taking it apart and using the correct flywheel as he wanted to counter balance it on the front or some s*** Thanks guys for helping me out here. Gave me some knowledge so I didn’t just do whatever he was telling me..
Kyle,
Glad we were able to help and it's now running like it should. I'd say it's time to find another mechanic! |
schultz227
I know, my local Nautique dealer will not work on my boat due to its age... ever hear of such a thing? Lol
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
1st problem Mechanic without the knowledge to work on your boat.
2nd problem O'Reilly auto parts a good place for oil ,wiper blades or air fresheners. Not so good for real parts. Refer to 1st problem. |
