Accelerator Pump Squirter Assy Question |
davidg
Grand Poobah Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Posted: November-03-2019 at 5:45pm |
Hi Guys! I pulled the carb off my '87 Martinique (351 w/4160 carb) to have a look at it in the off season. Seems to run pretty good with the exception of a fairly consistent stumble when you hit the gas. So, I took a look today to see what might be happening. First thing I will do is fine tune the accelerator pump arm to tighten it up a bit (less slop).
The other thing I noticed was the squirter assembly. There is the #25 nozzle, washer, and a needle valve (I assume pointed end goes down....I didn't see how it came out). Question: Is there supposed to be a steel ball under the needle? Anything else that might be worth checking out for the off-idle stumble (and difficulty in starting without a couple of gooses on the throttle after it fires once and dies)? |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
Here is a link to an exploded view of the carb (compliments of Holley's Library). You may find your answer there.
LINK |
davidg
Thanks JQ! That is very helpful. Looks like there was a check ball used in the mid-70's and earlier carbs. I think I have everything based on what I'm seeing in the schematic.
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10640 |
Like you said, you have everything you need for a later carburetor.
