Ford 302 RR Distributor Gear |
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 276 |
Posted: November-26-2019 at 1:08pm |
I have some Ford 302 Reverse Rotation Composite distributor gears for sale.
They were made for the 302 with .467" ID but you could open it up to fit the Ford 351 shaft as well. If you are thinking about upgrading to a roller cam, you will need one to replace your original cast iron gear. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10649 |
'Bout time you decided to get some of that investment back Steve
And.............they'll work with any cam gear material |
Mille1sj
Yeah KENO, I wanted to make sure the gear worked for me and I got some hours on it before others tried it
Marseille
Newbie Joined: April-24-2018 Location: Jax Status: Offline Points: 19 |
Thanks for leading me down this path from the junkyard GT40p thread. Feel like i'm running into dead ends with RR flat tappet cam. A roller cam? LSM Engineering? Should I just give them a call?
'83 SN
99airwarrior
Senior Member Joined: August-19-2019 Location: Reno Nv. Status: Offline Points: 129 |
Hi how much are you asking for a gear? Thank You Joe
