D.U.I. Marine distributor |
99airwarrior
Senior Member Joined: August-19-2019 Location: Reno Nv. Status: Offline Points: 129 |
Posted: December-22-2019 at 2:49am |
I Have two Davis Unified Marine distributors. One has a standard rotation gear. The other has a CCW rotation gear that I have in my 1985 2001 351w ccw rotation. Can I swap the gear from my ccw distributor to the new standard rotation distributor or is their a difference with the advance weights ? I know the module and pick up are the same. The standard rotation part # is M35820bl and the CCW is part # M35820RRBL. Thank You Joe
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
The only difference in the 2 distributors is the gear.
A distributor for a RR 351W rotates CCW and a distributor for a normal rotation 351W also rotates CCW. This is because the cam gear and the distributor gear are cut differently from each other on the 2 engines. So the answer is yes you can swap gears If you're not familiar with the process do a little reading about removal and installation of the gear on a 351W. Google is your friend, or ask here |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2822 |
Based on the part numbers you provided in the post, both match up with a SBF Windsor 5.8 engine. As such it is highly likely that the weight and spring assembly will provide identical timing curves (provided both units are bone-stock and unmodified).
The last 2 letters indicate distributor cap color. You may want to exchange the "BL" unit for an "RD" unit as the red cap will make your boat go faster. Just sayin..... JQ |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
Why swap?
Jonny,Jonny,Jonny Let him in on the rest of the secret, he needs RED wires to go with the cap RED may be faster than BLUE, but is it as fast as a CLEAR cap ? Just wonderin............. |
99airwarrior
Thank You for the help
