Priming Fuel Filter Canister? |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Posted: January-15-2020 at 7:01pm |
Hi- I recently replaced the fuel/water separator filter on my 89 SN 2001. It’s the filter with the original canister. I emptied and cleaned out the canister prior to installing the new filter. Now, I’m not getting gas to coming out of the fuel pump to the carburetor. I am getting the air pulses coming from the fuel pump, just no gas. Tried cranking many times. Do you have to prime the pump or fill the canister after installation prior to restarting? There is a brass plug at the top of the canister but I’m not sure what it’s for. What am I missing? Thanks for any help here! -Gene
Hollywood
Thanks(1)
You displaced gas with air. Is gonna pump air for a while.
The little plug at the bottom of the canister is a drain. You’ll only further displace gas with air if you remove it. Yes, I would have done what I could to refill the canister with gas before reinstalling. |
bfootr
Thanks. I literally tried to crank the engine for an hour or so being careful not to over heat the starter. I took outlet line off of the fuel pump just to confirm no fuel. Is there anything else I should do to get the pump primed? Also, I was referring to the brass plug at the top of the canister (on the lid). What’s it for?
Hollywood
Thanks(1)
Probably a vent if you did try to use the bottom drain plug, otherwise you kinda have a vacuum...
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10648 |
Thanks(1)
Take the flame arrestor off, dump a little gas down the primary bores of the carburetor and it should fire right up, it may stall once or twice and need another shot of gas each time till the filter canister is full and things are back to normal and it stays running. Rev it up some to get that pump doing some good pumping. and your canister will fill right up.
The fuel pump will suck a lot better when the engine is primed and then running as compared to cranking it over at a few hundred RPM's. Put the arrestor back in place just in case of a backfire so it can do it's job. You could also do a shot of starting fluid instead of gas, but that would start way too many arguments about starting fluid |
Thanks(1)
Bill
Were you having problems that led to a filter change or were you just changing it as a preventive maintenance type thing? Only reason I ask is that you've been through a couple of the newer cheaper built Carter mechanical pumps and hopefully another one isn't crapping out on you. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2842 |
Thanks(1)
+1 What KENO said. I stay away from starting fluid. I pour a couple of tablespoons of fuel down the carb bore. The engine usually fires off quickly. As Ken said, you may have to do this more than once. Saftety tip...keep the gas container well clear just in case you get a backfire out the carby. The engine will turn over many more times when fired up from fuel down the carby vs. cranking with the starter. Bad ju-ju for the starter, too. JQ |
bfootr
Preventative. And you’re right and that thought did cross my mind, especially due to the fact that I’m on my 3rd Carter pump in less than a year.
I did try squirting gas down the primary side several times which did start the engine but only until the gas burned away. Wouldn’t keep running. No gas coming from the pump only the air pulses. |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1114 |
Thanks(1)
Check the gasket on the filter canister. Don't ask how I know this. It may not be seated or it's not tight enough.
bfootr
Thanks everyone. I’ll check all of these suggestions tomorrow. Really appreciate being able to leverage the expertise on this forum.
Thanks(1)
With that extra info, I think Desertskier's suggestion sounds good
If your gasket is tight and the filter is all buttoned up and still no luck, hook up a temporary tank to the pump suction and see if it runs. If it runs, move the temporary tank back to the filter inlet and see if it runs. I figure Desertskier has your solution though |
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 276 |
Thanks(1)
I disconnect the hose going from the canister to the fuel pump and hooked a pneumatic pump you would use for bleeding brakes to it. It quickly pulls fuel from the tank primes the canister without running your fuel pump dry.
bfootr
Great tips. To close this loop, I took off the canister and verified that the seal was intact. Filled it up with gas, re-installed it, squirted the carb with fuel a few more times and it worked. I think the canister was loose and not sealing properly. Great call-out desertskier. Thanks again for all the help!
