Newbee Question |
terryray
Newbie Joined: September-25-2006 Location: United States Status: Offline Points: 2 |
Posted: September-25-2006 at 12:08pm |
Just Bought a 79 Ski Nautique First Boat I have ever owned with a straight Prop. I have a squelling noise some times when accelerating from a stop. V belts are very worn. They are the first thing I am going to replace. for the noice . My question is can you run the boat and spin the prop dry out of the water. just for a short time to try and diagnose this problem ( I realise it will have no cooling. ) Also do they make a connection that you can hook a water hose up to it for cooling. Thanks for you help
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Here's a solution from Overton's. I don't think anyone here would recommend running your engine without water. You can damage the cooling system, let alone overheat your engine.
Fake-A-Lake Ken |
Nautique2001
Nautique2001
By the way, Terry, welcome to Correctrcraftfan.com. Post some pictures of you boat!
Ken |
jimbo
Welcome and congradulations. Even with the fake-a-lake or cooling attachment, I don't reccommend putting the boat in gear and winding it up. It's bad for it plus I'm sure you won't have the noise because the boats not under load.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6107 |
A few extra thoughts. You don't want to put the boat in gear in the driveway because you can fry your packing and bearings in the shaft log (where the shaft goes through the hull) and in the strut (the bracket that holds the shaft under the boat) You don't want to run your boat dry, not only because of the overheating issue, but you can rip your raw water pump impeller to shreds. The devices mentioned above are good, but you may also find that if you disconnect the water intake at the thru-hull fitting back by the transmission, a garden hose will fit in it just right, just be sure to retighten the hose clamp around it. If your raw water hose is too big, I fashioned a fitting out of some PVC parts that goes from hose fitting to a piece that fits snugly in the hose. Cheaper and easier, if you don't have a marine supplier near you. Oh, and it does just sound like warn belts. Welcome to CCFan.
quinner
One other thought, do not rev the engine while connected as 75 described, the suction may collapse the hose and not allow enough or any water to reach the impeller. One other way to run out of the water, similar to what 75 described but put both the garden hose and your intake hose in a 5 gallon bucket, turn hose on, when bucket is about 3/4 full start the engine, if you rev the engine this way you will see the water level in the bucket drop, once at idle again the water level should remain constant or rise slowly.
79Tique
Senior Member Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
I push my garden hose in the hose leading into the pickup pump and tighten the hose clamp on my 79 Ski Tique. I run the boat this way but only do a little reving. I have never had the hose suck flat but I do blast the garden hose at full pressure. This is a way to run the boat befor you get a chance to buy the right tool.
I'm a Newbie as well, these folks have been very helpful over the last few weeks. Welcome CCF! |
Work to live, not live to work.
79nautique
screw the fake-a-lake crap and save your money, put a hose into the pick-up hose and be done with it.
Randy_in_Ohio
I bought a fake a lake a couple weeks ago. I'm taking it back. It doesn't seem to get a good fit around the indented part of the hull where the water intake is. Also, I don't think the engine is getting enough water, seemed that the exhaust manifolds were getting hotter than they did in the water.
I am going to try getting a clear piece of hose from Home Depot and a trash can. Use the trash can as a resivor for the engine to suck water out. I want to find a way to secure the hose to the can so I don't have to worry about it falling out. I read something similar to this setup on here, sounded like a good idea and a more natural setup than the fake a lake. A mechanic at a local marina said to be carefull if you put the garden hose into the intake hose, he said if the engine is not running when you turn the water on you could get water in the cylinders. He suggested having someone stand by the faucet and turn it on as soon as the engine fires. Terry- Welcome, this is a great place you have found, some really good people here. Good luck with your new boat. lets see some pics |
hspore
Senior Member Joined: January-11-2006 Location: United States Status: Offline Points: 164 |
...listen to 79' and save your money. He's great for practical advice like that and has helped me a lot. Welcome to the CCF site.
Heath
79Tique
Ohio, How would you get water into the cylinders from the cooling system/ water jacket without somthing being wrong?
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
Yeah just use a hose,that's all we've ever used. The hose may flatten a little bit, but as long as you're not revving the heck out of it it wont be a problem, save your money.
Nate |
terryray
Thanks for all that replied. I could tell just by reading the forums when I found them I would get some good advice if I posted a question. Thanks again for all that replied.
