1984 2001 restoration with new graphics |
Kjerchinger
Newbie Joined: March-31-2016 Location: Minooka, IL. Status: Offline Points: 30 |
Posted: May-29-2020 at 1:27pm |
Attached are pics of my recent restoration, floor, and secondary stringers, Graphics by Harmonic Design in Channahan, IL. they did an unbelievable job creating OEM graphics from pictures I provided of similar boats. |
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 931 |
Saw the graphics on Instagram. Impressive. Put a side view pic up. While I like original, that decal work looks great. And your interior is on point too. Congrats!
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 552 |
That turned out very nice. Great job
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out) |
Kjerchinger
Thank-You
I posted many more pics than what loaded. I am a better carpenter than IT guy. Can’t figure out how to post from my phone, I’ll try again on Monday from my work computer. |
Keith,
Very nice indeed. Great job. |
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 402 |
Looks very nice !!
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4231 |
Really sharp looking, impressive work!
Kjerchinger
Thanks for all the nice comments !
I will try and post more pics, but seams like I must start a new topic to do so. sorry I am so technically challenged. Keith |
No, you can post in the same thread and even in a previous post by clicking on "edit". |
SNBob
Newbie Joined: April-23-2020 Location: Boise, ID Status: Offline Points: 1 |
Is that some sort of wooden floor installed over the top of the fiberglass floor? I have not seen that done before, it wasn't that way from the factory was it? What is the reason for it? My fiberglass floor is a little soft in spots and certainly uneven. I'm wondering if this would be a solution to make mine level again.
82'CC_SN2001
Newbie Joined: June-04-2020 Location: SC Status: Offline Points: 7 |
Very Nice!
Fabcon
That color combo is very nice.
Kjerchinger
Hi Bob,
I removed the existing fiberglass and flotation foam, then found I needed to replace the secondary stringers too. though going over the existing floor could mitigate your soft floor issues, you would not be getting to the root of the problem, water below the floor, soggy flotation foam, lots of bad stuff you would just be covering up, maybe stringers are in bad shape too. After rebuilding my secondary stringers with 3/4" and 1" cossa board, I used 1" Cossa. as a sub floor under the front seats, installed tight to the Port & Starboard Hull. then I went over that with 1/2" Divinycell, using that on the remainder of the floor, if you reference my photos, you'll see I used it to establish the floor height at the Hull. both these products are very pricey, some would say I went over board, I'd have a tough time arguing that point. Yes, I could have used wood, but a primary objective I had was to make the boat as light as possible. Cossa is 40% lighter than wood, and has only 1% water absorption ability, I coated it with Resin to eliminate that entirely. the Divinicell is entirely foam, very light, 3 coats of fiberglass is recommended on the underside prior to install, followed by 3 coats on top after install. once that was done I drilled holes in it to pour in new foam. |
repifanio2
Groupie Joined: June-25-2017 Location: 53121 Status: Offline Points: 53 |
Where did you get the graphics, I have a 1986
RKE
Kjerchinger
A local shop, Harmonic Designs, Channahon, IL.
It is a wrap, 3m vinyl. I sent them many photos of like boats, the created digitally. The hard part for them is done, to recreate, they would just need to used different color vinyl to match your needs. I paid 1050.oo a deal in my mind, but they said it took much longer than they thought. If your not from the area, maybe you could purchase the graphic from them, or they might sell the file to a graphic shop in your area. They did an amazing job. I really have a hard time uploading photos, if you send me your email, I’ll forward you some more. Keith |
