Water in battery box |
nomemolesto
Newbie Joined: June-06-2020 Location: Switzerland Status: Offline Points: 6 |
Posted: June-17-2020 at 6:29am |
I just became the owner of a CC SN 2001 / 1987. When I open the battery box there are two holes: One for the power cable and a smaller one at the bottom where a small amount of water comes in and out. Is this normal?
slmskrs
Gold Member Joined: January-03-2012 Location: SF bay area, CA Status: Offline Points: 522 |
It's a drain hole in case water gets in the battery compartment. There is supposed to be a plug in the hole normally to keep water from the bilge out. The original plug in my boat wore out and started leaking so I replaced it with rubber stoppers.
Gordon '97 Ski Nautique, GT40
nomemolesto
Thank you for your fast reply, very helpful. I will use a champagne cork to seal it.
slmskrs
