Fuel gauge fix? |
Author | ||
DockDoc
Senior Member Joined: February-17-2014 Location: Charlotte, NC Status: Offline Points: 474 |
Posted: June-25-2020 at 8:47pm |
My fuel gauge is a accurate to about a half a tank. Needle bounces around like mad if it’s not totally full.
Is there a reasonable fix for this, or is this a boating inevitability? Seems like every boat I’ve had is the same but it’s getting annoying not knowing how much fuel I have. |
1993 Sport Nautique
PCM 351w, no ProTec |
Tyler,
Go with a high end linear sender There very nature snubs rapid movement. |
DockDoc
Ok will do, appreciate the rec - any idea what length I need? |
1993 Sport Nautique
Tyler, Sorry but I don't know the length needed. If you don't get a response, then you'll need to measure your tank. |
zwoobah
Senior Member Joined: September-13-2018 Location: Providence RI Status: Offline Points: 308 |
I installed a Kus sender last fall - similar to the Moeller unit that Pete posted, but only about $50 on ebay. Read the instructions before you order a sender: If you're installing in a metal tank it should be 1/2-1" shorter than the tank depth, a plastic tank will need more clearance.
1968 Mustang 16 - 351W powered
DockDoc
Thanks I'll check that out too! |
1993 Sport Nautique
Hysteria
Groupie Joined: May-31-2020 Location: Indiana Status: Offline Points: 70 |
Could you explain what you mean by snubbing rapid movement? I have a reed switch sender in my boat and don't feel that it resists fuel sloshing any better than the factory style sender |
Isaac,
From the Moeller description: "Reed switch sending units collect fuel level information more consistently than swingarm senders. They achieve this by taking the measurement from the float - which is still a moving part. However, the fluctuation is much less because the range of motion is much less." Another: Moeller Marine Reed switch fuel level senders dramatically reduce "slosh fluctuations" which are inherent with swingarm units. " Did you use a Moeller brand? |
Hysteria
No, I'm using a Wema sender. I don't think it's a bad unit by any means, but the gauge definitely twitches between different fuel levels (due to the low resolution of the reeds) when the boat is moving. |
DockDoc
Yeah mine usually sits around 1/2, and twitches between empty and full. Basically useless. |
1993 Sport Nautique
Isaac, The "twitch" between levels should still give you an idea of how much is in the tank. |
Hysteria
It does, and I would consider it to be a perfectly functional fuel level indication. I just don't feel that they do much to dampen rapid fluctuations. |
Marseille
Newbie Joined: April-24-2018 Location: Jax Status: Offline Points: 19 |
Does anyone know the standard/typical shaft length for a 1983 Ski Nautique with a metal tank? It has the original swingarm style sending unit. At key on, gauge pegs full when a jumper is placed between the ground and the sending unit wire, otherwise, it's a random level generator. I can pull the tank and check but I thought I would ask in case someone has the length handy.
'83 SN
Anyone have any experience with Tanks Inc. floatless senders?
Tanks Inc. sender I was shopping for a 0 to 30 Ohm sender for my X55 and ran into it. I wonder how well it solves the gauge "twitch" problem? |
