pressure sensor tap |
dynasim
Newbie Joined: July-27-2018 Location: Kansas Status: Offline Points: 26 |
Posted: July-01-2020 at 11:53pm |
Is the plugged hole that v's away from the pressure sensor a second place to take the oil pressure? I want to install a pressure gauge.
Thanks for all the help, and the tolerance of stupid questions! Chris |
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
It looks that way to me
Chris,
It doesn't look like you would be able to swing/turn even a 1&1/2" diameter gauge directly in that tight area so, you would need to do the same as they did with the pressure sender. See that they used an additional nipple and coupling to move the sender away from the housing. The alternate is a union or I'd put a "T" where the coupling is below the sender. |
