Overcharging the battery |
Post Reply | Page <12 |
Author | |||||
Nathan,
My choke coil reads at 11.5 Ohms across the coil and 11.7 to the engine block. Check yours both ways just to make sure the coil isn't shunted to ground.
NMiles77
Newbie Joined: August-22-2020 Location: Ohio Status: Offline Points: 9 |
Pete I put my DMM across the choke coil. I had 7.1 ohms and 7.2 ohms to the block. So it’s not shunted. We will put the boat back in the water tomorrow. I will again measure the voltage across battery when the engine is running.
NMiles77
Ken post both pictures of the wiring
of the one and three wire Delco alternators, I was looking at them on DB website. The one wire is very tempting and the price is right. |
The resistance on your choke coil is low. Ken calculated 10 and I was getting arond 11.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10699 |
Ken didn't calculate 10, he just gave that as an approximate value. I've seen then anywhere from 7 to 13 ohms and they all worked. It isn't gonna have any affect on his charging voltage.
Here's a picture of hooking up a 1 wire Delco If you can count you'll say "but there are 2 wires" They don't count the ground wire for some reason. You don't really need the ground wire because the case is grounded to the engine through the mounting bolts and a lot of people don't use it but it's pretty easy to put it on. Hooking up a 3 wire Delco (with 4 wires counting the ground) Same Black ground wire hookup and Orange output wire hookup The Red wire is the sensing wire for the internal regulator and in your situation hooking it to the output terminal works well. The black wire next to it that's hooked to the green wire is the 12 volt excitation for the alternator. The Green wire color is just because that's what I pulled out of the drawer The 1 wire alternator is "self exciting". When you start the engine and rev it to a little over 1000 rpm's, the alternator is now excited and starts charging.Once it's charging, it will keep charging till you turn the engine off. Then on the next start, you rev it to 1000 or so and it's charging again. You can come down to idle speed and it'll keep charging as long as you revved it enough to excite itself. The 3 wire needs 12 volts from a keyed ignition source to make it's regulator start charging. No revving it up is necessary. The 3 wire can sense system voltage anywhere in the electrical system depending on where you hook the wire to. In your case with a boat that doesn't have any big electrical loads, sensing right at the output terminal works well. And.......since any of these alternators are a lot more powerful than your original the easiest way to protect your boat wiring which won't really handle much more than the original alternator's 37 or 40 or so amps is to put a 40 amp fuse right at the alternator output. You won't use all the amps the alternator can put out if you get a 100 amp alternator, you're basically limiting it to 40 amps. Some people just slap on a 100 or more amp alternator with no fuse at the output and can under the right circumstances melt wiring, make all kinda' sparks under the engine box and that's never a good thing Here's a picture of a fuse setup that would work. The wiring to the fuse should be at least as big as the 10 gauge alternator output wire. If you want to use all 100 or so amps, then to be protected you'd need some larger wiring all the way from the alternator to the ammeter in the dash and back to the engine again and you'd need the same size ground wiring. The simplest but still effective setup would be the 1 wire alternator with a 40 amp fuse on it's output and the rest of your boat wiring could handle that. Like with most things in life, there's more than one way to do do it, so maybe you'll get some other opinions. |
What worked? The electric choke or the Escort charging system with 7 to 13 Ohms at the choke coil?
Those things that read anywhere from 7 to 13 ohms.........they're what worked. And the choke coil is gonna have no effect on his charging voltage, like I said in the same quote,so he'll still have his charging system issue |
Ken, What is the resistance of the choke coil doing for the regulator circuit?
I guess you should tell me, you're the one who brought up the choke coil to begin with
Ken, Yes I did bring it up after checking the alternator/regulator wiring on the Escort and finding the connection to the choke coil. I don't know what the resistance in the circuit is doing and it sounds like you don't have any idea ether!
I guess I don't know what you're thinking but it's(the s terminal) just a handy place to grab 12 volts and feed it to the choke No feed to the alternator at all from that wire
Ken, My thinking is why did they what resistance on the REGULATOR. BTW, the "I" terminal on the start relay is closer than the regulator so, that's an even HANDIER spot to pick up 12 volts.
We might set a record for number of quotes in one post here Pete You need to think about when the "I" terminal actually has any power supplied to it and then decide if that's what you want powering? your choke Pete
Got that "I" terminal figured out yet Pete
Edit.........I guess you're still figuring it out Pete, but for anybody else that's reading, the "I" terminal only has power when the key is in Start and no power in Run, so it's not of any use for powering the choke or providing voltage to the "S" terminal when the engine is running.
