  New Posts New Posts RSS Feed - priming raw water pump?
Poster112 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Poster112 Quote  Post ReplyReply Direct Link To This Post Topic: priming raw water pump?
    Posted: October-14-2006 at 10:01pm
After removing my impeller on the raw water pump for winterization, I realized that I still need to run the engine once more to fog it. So, I put the impeller back in. Do I need to somehow prime the pump to get water in the impeller so that it does not melt? I'm doing this in my driveway and usually run a hose through one side of the filter housing or using a fake a lake. Will the impeller suck air well enough to prime itself?
I know that if I was on the water, the pump would have help from the lake water coming in and trying to displace the air in the hose on its own. Does water usaually drain all the way out when the boat is pulled out of the water, or does enough remain in the pump housing (between the vanes)to keep it primed? My pump is bone dry right now and I do not want to melt the impeller.
Thanks.
I'd rather have a bottle-in-front-of-me than a frontal-lobotomy.
1985 Ski
1984 SW
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2006 at 11:40pm
No need to prime the pump. The rubber vane impellers are designed to lift water and prime themselves very quickly, you won't harm the pump. Just make sure you turn the water hose on before you start up.
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2006 at 1:56am
agree...no need to do anything but start her up with a hose on it! Water will reach the impeller quickly.
stang
The Super Air
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2006 at 9:29am
If you have a waterhose hooked up and turn it on it will get to the pump instantly. When I winterize, I put antifreeze in the block. I take the raw pump off and with a water/antifreeze in the block I can start it and let it run a few seconds, to lube everything and to keep the carb from drying out. The only thing to watch is the temperature onexhaust manifolds.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2006 at 9:48am
Tim, I always worry about running the engine without water flow. The temp rise in the exhaust is extremely fast and I figure warping can occur even when running for a short time.
I have a jet boat with aluminum manifolds, maybe I'm just gun shy because I had to have them machined to flatten them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2006 at 12:39pm
I'm talking about only 5 seconds or so. They don't even get warm to the touch.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Poster112 Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2006 at 1:41pm
Thanks, Guys. That is what I suspected, but just wanted to be sure. I never had to winterize my Boston whaler's outboard when I lived in FL. This is my first inboard and my first time to winterize.
As always, thanks to all of you folks that responded. In the few months that I've had her, I have learned so much from you guys.
Much apppreciated!
Chris
1985 Ski
1984 SW
