1.23:1 transmission compatability |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Posted: October-27-2006 at 1:40am |
Can anyone tell me if you can bolt the PCM 1.23:1 transmission up to a chev engine.?
I know some nautiques have an apex (chev) option, so I'm guessing it is possible. Maybe with an adaptor plate or something.? Anyone.? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21123 |
Yup, they should work. All the new CC direct drives have Chevy motors (5.7 Excalibur, 6.0 ZR6) and come with the 1.23:1 tranny.
eric lavine
chopper, i believe i have a bellhousing to bolt up that trans eric
Chopper
Eric,
What's a bellhousing worth.? I may not need it, but if I do, I'll let you know. |
79nautique
if you don't have the right bellhousing you won't be bolting the tranny to anything and you won't be able to use the bellhousing that is on it if it was mated to a ford motor.
Chopper
what I meant was I don't know if I will be replacing the pcm windsor with a chev based block. windsor parts are hard to come by here in oz. chec parts are dime a dozen. I'm just looking at options if the motor is a dud. |
