Winterizing the boat |
JeffL
Newbie Joined: September-11-2006 Location: United States Status: Offline Points: 12 |
Posted: October-30-2006 at 5:06pm |
Hey guys just started to winterize the boat. I filled the fuel tank and added stabilizer, but I can't get the coolant to pump through the motor. Is there a thermostat that has to open before it starts pumping, or is it time for a new pump? I unhooked the line from were the tranny lines hook in and put it in a bucket of coolant and it did nothing. Also were would I get a new pump, and is there anything else I should do to winterize? First boat I ever owned so not real familar with the winterizing process. Thanks
1968 CC Mustang 302ci |
Guests
Guest |
take a 5 gallon bucket and dump 3 gallons of antifreeze into the bucket. fill rest with water. hook garden hose to water inlet hose. start up boat let warm up to temp. shut down open pitcocks aloow water to drain from the block. close them, then sitck inlet hose into bucket and start boat up, allowing antifreeze water mix to be sucked into block. immed. take a can of fogging oil and for engine. shut motor down..do these steps as quickly as possible.......i then remove battery, hose my motor down with wd-40, and add 2 boxes of moth balls and a bucket of charcoal for moisture.. this whole proces should take 30-45 min.
Guests
Guest |
............forgot.............if the motor isnt sucking water your impeller could be toast..take off water pump and see if your impeller is in good shape....if so, then your pump may have to be replaced. tranny lines? confused on what your hooking up here?.you need to hook up the intake hose(going to the opening on the bottom of your boat).........68?...maybe try www.skidim.com!......hope this helps!
Poster112
Senior Member Joined: May-28-2006 Location: United States Status: Offline Points: 206 |
Check the current boat maintenance threads. There is one right now that will give you a ton of info Otherwise do a search in the forums.
