2004 330 Excalibur knock sensor |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1726 |
Posted: February-14-2023 at 9:10am |
Is there an automotive equivalent that I could get locally as a replacement for my 0-2 sensor? Part number or application?The threads are missing towards the end and it’s difficult if not nearly impossible to get it put in the block. I have already tried chasing the threads and it did not help at all.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
I assume you chased both sets of threads? (Block and sensor)
fanofccfan
Yep sure did. Not that you can see via the picture but about half of the first thread is missing.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10673 |
Here's a picture of a knock sensor from a 96 Chevy Silverado 5.7 Vortec engine which is what the Excalibur 330 is based on. It's 1 1/2 inches in diameter has a 7/8 hex and the threads are 1/4 inch pipe threads (1/4-18) The part number is kinda hard to read in the picture but it's 10456288, etched into the metal. Yours should have a part number like that.............I figure it might be the same part number If it's a different number, a Google search should help find something. If it's the same part number and you want to be daring, go to Ebay and punch in that part number and there are zillions of cross referenced copies from "overseas" starting at about 7 1/2 bucks or click on the link.. PS..............I think you're missing a few rows of threads |
fanofccfan
Thanks again Keno. ill have to sand off the paint.
I found something that says that GM engines using MEFI 1 through MEFI 4 use GM part number 10456287 so there's a good chance yours might have that number instead of 10456288.
Same search with that number will turn up lots of cross reference choices I don't know what the difference is between the two sensors. An 04 EX 330 is a MEFI 4 system.
fanofccfan
I am off to the wire brush to find what it says!
fanofccfan
or maybe its 10456126 and below that is 1084-2F
now to find out if local store has or can get one.
Just in case, here's a link to Rock Auto that gives a bunch of cross referenced sensors that you could use at the local store |
fanofccfan
I guess you won't be skiing on your birthday
fanofccfan
Nope! 10" ice yet. Fat tire bikes are my only lake activities as of late.
