Gas Leak at brass fuel line connection |
91NaughtyQ
Senior Member Joined: July-27-2015 Location: NC Status: Offline Points: 287 |
Posted: June-30-2023 at 8:33am |
My 1991 Nautique (700 hrs) has developed a small gas leak at the bottom of the brass fuel line from the Diaphragm pump up to the carb. It is leaking at the connection of the brass tube and elbow joint.
Line was replaced somewhere around the 400 hr mark.
I checked the connection and it is tight. Is there an O ring inside that connection that you know of that may need replacing or do you guys have a recommended solution other than a new line? Thanks in advance. Gary |
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001 |
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10680 |
Here's a picture of what's at the fuel pump.
You have an inverted flare fitting and the fuel line is flared to match the fitting. When you tighten the nut, you're tightening the flare down against the inverted flare inside the fitting. The seal is provided by metal to metal contact with the nut holding them tightly together, with no gaskets or sealant of any kind Any leakage out the threads means the seal between the tubing flare and the inverted flare is bad Trying to seal the threads isn't gonna fix the problem. Replacing the line and the fitting together should fix the problem. The inverted flare fitting (your elbow joint) is called a "90 degree elbow inverted flare 3/8 tube X1/4 male pipe thread fitting" Just to make finding one easier, here's a link to a bunch of different places The pipe threaded end that screws into the fuel pump can get sealed with gas resistant sealer, but like mentioned above, no sealer where the fuel line nut screws into the fitting |
91NaughtyQ
Appreciate the info as always. For the record when I put it on a few years back I did not have flare wrenches - I bought some today and was able to tighten it about 1/2 turn more. I haven't started it and tested the joint yet but if it still leaks after that then replace it right? If so have you used the flexible ones that Ski Dim builds or do you have an opinion on it?
Thanks as always! Gary
1991 Ski Nautique
I was gonna say, grunt down on it a little more but you said it was tight. I guess it's a little tighter now.
Maybe that'll do it for you. USCG approved rubber hose or metal, it's your choice. Me...........I'm a rubber hose kinda guy, but everybody has their preferences |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6103 |
Sounds like someone is anxious to get out and do some skiing
91NaughtyQ
Don't you know it sir. After 3 yrs off skiing last weekend - you couldn't punch the grin off my face. What's crazy is that you don't forget how to ski, you just lose some stamina behind the boat. If you tell me to pick only one sport for the rest of my days skiing gets the nod.
1991 Ski Nautique
91NaughtyQ
Well I thought it was tight however...... I picked up some line wrenches and I was able to go another 3/4 turn tight and all is good sir. Also found I needed to snug up the 4 screws that hold the accelerator pump in place. There was some surface fuel around the seal. All in all no more leaky smelly gas.
1991 Ski Nautique
91NaughtyQ
KENO -
Just a quick update. It started to drip again, so I just went ahead and ordered the rubber line from Ski Dim which will be here today. Appreciate the input.
1991 Ski Nautique
