Tire Pressure |
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
Posted: April-26-2007 at 11:01pm |
I have an 82 2001 CC trailer, single axle. I have the boaters word tires & rims that are the same size & look as OEM.(1700 load I think )What tire pressure are you guys running. These tires only say 50 psi cold on them. Thanks ,Dan
bkhallpass
Probably not much help, but both my trailers are tandems. Load capacity on each tire is 1430lbs and tire pressure cold is 35PSI. BKH
Livin' the Dream
Dans, The ref section says that your 82 weighs 2350lbs. plus say 600 for the trailer less 150 for the tongue weight comes out at 2800lbs or 1400 per tire. I don't feel the tires need the full 50psi with that weight but I wouln't go less that about 45. Put 45 in and see how they run. If they are too hard then lower the psi some but keep a eye on them. You don't want them to run real hot.
