Adding ATF to gas |
1998Nautique
Senior Member Joined: January-26-2006 Location: Canada Status: Offline Points: 190 |
Posted: May-15-2007 at 11:17pm |
A friend told me he adds some ATF to his gas, does this sound right. Or should you add it to your oil. Or is it a bad idea?
p/allen
Gold Member Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
For what purpose?
Pat |
1998Nautique
Lube up the engine.
p/allen
I have never heard of this . I dont see any reson for it unless it has been sitting for many years . Even then I would use regular oil inside the spark plug holes with the plugs out .
Pat |
It would be for top cylinder lube. Same principal as adding Seafoam, Rislone or Marvel Mystery. I rebuilt my little flat head 4 in my Atom then put it in storage for about 10 years before it went in the boat. On start up I had a stuck valve and remembering the Marvel oil the old mechanic used at the marina I went and got some. The stuck valve was free and the engine runs great. I still add it to the gas occasionally. I do use it as a fogging oil. ATF is a high detergent oil that will keep the combustion chamber clean.
eric lavine
it is high dtetergent, and an old timer once told me to add atf to the crankcase a couple of days before an oil change because of the high detergents. other than that who knows?
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Snake oil from the days of splash lubrication.
River Rat to Mole |
quinner
Never heard of adding ATF to gas but have heard the same as Eric about adding it to the crankcase oil prior to a change.
Used to use a lead additive in the gas of my 77' and 80' SN's as I was told the older original motors needed it to lubricate the top end. |
87BFN owner
I knew a guy that used to drain the old oil, fill it back up with a new filter and ATF then run it five hundred miles then drain. Replace filter with another new one and add fresh oil.
Never heard of ATF in the gas though. |
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
I burn 30% waste crankcase oil , 70% crushed soy beans in my truck , total cost about 1.50 a gallon , plus it smells great
Jim_In_Houston
I burn the neighbor's gas in my vehicles so what ever he uses I use. I only siphon a little each night so he doesn't miss it.
jbear
Man am I glad J_I_H is back on here. Where else can you get good tips, info, and J_I_H humor!?
john |
"Loud pipes save lives"
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Many old timers use (used) ATF as a top engine cleaner. I've seen several mechanics (a few who I really trust) just pour it (slowly) right through the top of the carb while the engine was running. I guess it would serve the same purpose when mixed with gasoline. Not sure if I'd use it at every fill up though.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
rudderdad
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 44 |
Jim you know that siphon hose is referred to as an Arkansas credit card. In diesel engines it is good practice to add atf to fuel at every oil change to help reduce cylinder carbon.
rudderdad
racintj
Senior Member Joined: May-09-2007 Location: United States Status: Offline Points: 163 |
Hogwash! That's what it is. I don't necessarily disagree with any of the ideas that ATF may help, but I wouldn't do it. Change your oil regularly (using quality oil), run good gas (fresh or use Stabil), and run it WOT quite often. The best known running engines anywhere are the post office and UPS. They stay running all day long, every day. No additives, and most run over 500,000 before rebuild.
Every day above ground is a Good day.
Lakeland, FL |
