Morse control is loose |
Author | ||
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
Posted: May-23-2007 at 1:16am |
Ever since I bought my Barracuda, the Morse control base has been loose on the side of my boat. It's supposed to be anchored by 3 bolts or screws. They're all in place, but only one is actually holding at all, and I can't get it to tighten.
How are these control lever bases supposed to be anchored? Is it supposed to be screwed to the fiberglass, or is there some kind of anchor behind the fiberglass the screw is supposed to anchor to? If it's the latter, how am I supposed to get to it? Do you have to cut a hole in the plywood below? If so, where and how can I cut so I don't damage the cables or anything else behind? Anybody have any suggestions as to how to deal with this little inconvenience? Thomas |
79nautique
there should be nuts I think on the back side of the screws.
tleed
Yeah, well, I was afraid of that. So how do you get to them to change these things? Or to replace the nuts that have fallen off?
The side panel may have to be removed but sometimes you can push it in far enough to get to the nuts on the backside. It's a tight area!!
Don't go drilling holes! They go on without the hole you're thinking of drilling and can be tightened the same way. |
tleed
OK, mine seem to be flapping in the breeze on the backside. As in, there isn't any nut for them to grab onto.
How do you get the side panel out? Mine's covered in carpet currently. Does it screw in around the sides? Thomas |
Thomas, Sounds like the previous owner did a non-original "restoration" with the carpet on the side panels! It is screwed on but now covered over with the carpet. Can you push the side panel in and temporarily put some small blocks to hold the panel back? If the nuts are missing, I have used this trick to get in tight spaces: Put double sided tape on the end of a hacksaw blade and stick the nut on it. Once the nut is started, you will be able to then get a open end wrench on it.
A mirror and lots of light will help plus don't forget to use flat washers and lock washers or flat washers and nylock nuts. |
The Lake
Pete, Well live and learn. Someone (I forgot who) said "Intelligence is the ability to function in novel situations." I'm glad there are some smart guys here who have great pointers. Chuck |
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
Not to thread jack this important discussion, but do they make kits to rebuild these controllers? My 76 SN is so worn, it has no dipression or Neutral position that you can feel anymore... Not a problem for me, but it's hectic for my better half to try to dock this way...
Moj |
05' SV211 TE
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
You sure its the controller itself? I assumed that the little bit of slop I have in the shifting of the throttle was the control, so I took it all apart, cleaned it and regreased it. Without the cables attached, it felt like a brand new piece- snapped and clicked at all the right detents. Reinstalled it and I have the same slop. The real cause must either be in the cable or transmission (most likely the latter). Maybe next year Ill try a new cable and see if it helps. |
Chuck, Thanks but I can't take credit for this idea. I think it was years ago that I saw it in Plant Engineering. I have however used the idea several times. When I was pres. of our local ACBS chapter, I used to write a collum in our news letter called "Pete's tips". I think I wrote 10 tips and then ran out of ideas!! Now I can't even remember them anymore. |
Mojo
Good question??? I'm only assumming the cams or indents are worn out? The controller works smoothly, so I also assume the cable is OK.. Until either breaks, I can live with it... Moj' |
05' SV211 TE
boat dr
Pete, I live by the old saying:
If you don't know surround your self with people that DO......boat dr " And this my boy is what this site is all about" |
