Sputtering/Backfiring Under Load |
Post Reply | Page <123 |
Author | ||
sjpitts
Senior Member Joined: April-16-2007 Location: United States Status: Offline Points: 111 |
Are you being serious? Honestly, I don't know. I just read about people getting 4400 RPM and 45 MPH. But maybe that is not stock, or something else. Jared |
sjpitts
I am really just guessing, but I am geting smoke at idle. I was told by a mechanic that it was running rich. I am pretty sure it is. It may just be at idle, but I am not sure. I should try that idle adjustment procedure, see what happens. Regarding the coil-- right now the old stock coil is in there. I have a brand new coil from SkiDim, but it is the stock replacement. I originally wanted to ship it back and exchange for "electronic ignition coil" (1.5 ohm) at SkiDim, but I am not sure I need to. As I said before, the electronic ignition conversion instructions recommend a prestolite 5-69 coil. I think that is 1.5 ohms. The stock "points coil" replacement I got from SkiDim measures at 1.7 ohms (as does the one that is in the boat), so returning it may not be necessary. Besides, I think most people just use the stock coil (bypassing the ballast resistor, of course) I was planning on calling prestolite to ask, but their website said they sold the distributor business. I haven't tried to call the new company yet. I probably should, I don't want to fry the new module. But I will definately try and fix the advance. I need to find a detailed explanation for taking the advance apart, replacing the springs, and lubing it up. Jared |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Jared, what color is the smoke you are seeing at idle? White (or light blue) is oil burning. Black is overly rich. Also as stated earlier in this thread, you can't depend on a plug reading that came out of an engine that was just ran at idle for several minutes. The plugs in your picture are also too cold for this engine. And then there's your timing advance issue. I'd get all of these items taken care of, then take your boat to the lake.... run it at cruising speed for about a minute, shut it down (immediately after cruise - no idle), change the plugs and save the ones you pulled for a plug chop. With your new plugs, finish your day on the lake and have fun. When you get home (or when you have time) cut the plugs open and look at them. You may just have your problems solved.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
nuttyskier2002
Jared, what color is the smoke you are seeing at idle? White (or light blue) is oil burning. Black is overly rich. Also as stated earlier in this thread, you can't depend on a plug reading that came out of an engine that was just ran at idle for several minutes. The plugs in your picture are also too cold for this engine. And then there's your timing advance issue. I'd get all of these items taken care of, then take your boat to the lake.... run it at cruising speed for about a minute, shut it down (immediately after cruise - no idle), change the plugs and save the ones you pulled for a plug chop. With your new plugs, finish your day on the lake and have fun. When you get home (or when you have time) cut the plugs open and look at them. You may just have your problems solved. Brian
nuttyskier2002
Sorry for the double post, no delete button.
sjpitts
I would say my smoke is black. Not white. The plug chop procedure sounds like a pain. Sitting on the lake changing plugs doesn't sound that fun. I may have to build up to that. Jared |
nuttyskier2002
Black smoke means you are way rich (too much fuel). This would be caused by a blown power valve or a choke that won't open or something like that.
'87Nautique2
Newbie Joined: August-12-2007 Location: United States Status: Offline Points: 17 |
Jared, did you resolve your issues with the EI? I just installed one and have very similar problems. A miss under load, mostly at mid-rpm's. See my post under Engine - Trouble after EI install. Did you ever replace the coil? Where did you end up on your timing?
