Possible fuel pump?? |
bill1
Senior Member Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
Posted: June-08-2007 at 6:02pm |
i took the 81 nautique out today afer finally putting an in-line fuel filter on. cranked fine, ran fine. after about 45 minutes of running the boat started sounding like it running out of fuel. it was. when i looked at my in-line filter, i saw no fuel in it. this is also a problem that i have before. now that i have an in-line filter, i see it is a fuel, or in my case, a no fuel problem. does a mechanical fuel pump do this? run great for a while and then all of a sudden stop, then start back?????
bill |
bill
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
The problem could be your pump but could also be a bad fuel line, clogged check valve in the tank, clogged pickup tube or other fuel filter (besides the one you just added).
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
