  New Posts New Posts RSS Feed - Finishing Stringers???
jon4pres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Topic: Finishing Stringers???
    Posted: June-25-2007 at 2:58pm
I have all of the fiberglass work done on my stringers and I need to know if I need to paint the exposed fiberglass and if I do what should I use?
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2007 at 3:43pm
You dont need to paint them unless youre not covering them up with the floor
Epoxy resin is susceptible to UV light, but thats not a concern for the glass on the stringers that are buried. Not a bad idea to coat the bilge though- gelcoat or bilge paint should do the trick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2007 at 9:10pm
Jon4, Tim is correct that the epoxy resin will turn whitish in time when exposed to UV. I wouldn't use a gel coat as I think it's a little overkill plus polyester will not stick to epoxy without a polyvinyl conversion primer. Tinted epoxy would be my first choice but people have had good luck with bilge paint too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2007 at 1:54pm
Thanks for the help guys. I will probably just do bilge paint. I dont have the rescources to spray gel.
82 2001
jon4pres@gmail.com
Fort Scott Kansas
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 2:36am
I used Bilgecote enamel over epoxy. Just had to be sure to wash with clean water and a scratch pad before applying the enamel. I also used a primer. It can be brushed on with a nice result. This brand or type of bilge paint is resistant to fuel, oil, and other bad things that tend to end up in the bilge. Makes keeping things clean a little easier.
Bill
http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
