  New Posts New Posts RSS Feed - losing speed
losing speed
81nautiqueskip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautiqueskip Quote  Post ReplyReply Direct Link To This Post Topic: losing speed
    Posted: July-09-2007 at 7:55pm
thanks in advance for advice. this site is a great resource. 1981 351 stock. i replaced the packing gore tex from skidim, set at 2 drips per minute. felt a little drag while cruising @ 25 mph. loosened to drip every 10 seconds still at cruising speed some intermittent slowing of speed. whats going on?
1981skinautique 3/4 done
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2007 at 9:53pm
81, Something else must be going on since I doubt if you would notice a drag from a too tight shaft packing. Was the shaft log (port) and packing assem. running hot?
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 10:01am
watch your tach carefully and let us know if you see any spikes or anything out of the ordinary when this happens, please post anything else that you can think of that might be different while you are operating the boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautiqueskip Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 11:14am
the packing assembly is running warm. not hot, warm. everything else seemed normal. i'll check tach carefully next outing. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 11:35am
81, They will run warm at first and then cool down so that is normal and not the intermittent slowing you are getting at cruising. Tell us more about the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautiqueskip Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 12:09pm
high hour stock 351/velvet drive/rebuilt carb/well tuned/runs really well/idles smoothly and accelerates to top speed perfectly/water temp steady/all seems good except this new light "drag" after repacking stuffing box.
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 8:48pm
I think you'd have to have an alinment issue to feel any drag as you speak of.Is it harmonic,equally spaced time wise between the increased drag?
Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautiqueskip Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 10:10pm
i don't think it's alignment. all redone floor/stringer's 5 years ago very solid feeling mounting bolts tight through rails and no problems before new packing. not equally spaced just a light intermittent rubbing. i'll put in thursday and try to be more specific. thanks. skip
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2007 at 3:07am
81....get under the boat and turn the prop by hand(not running of course)it should turn with very little effort and evenly with no binding spots. If it does not turn like that...see Eric's alignment post.
New floor, mounting bolts solid....thats all great , but the engine still has to be aligned!
Check it so you know for sure!
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2007 at 7:53am
I don't think it's alignment ether because the problem is intermittent plus it would take a major misalignment before you could feel it. With problems like this, sometimes you wish that it would just stop dead so you could find the problem! You may be chasing this for awhile. Have you looked at fuel delivery? Tank pick up, anti-siphon, rubber fuel line, fuel pump, PSI to carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautiqueskip Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2007 at 10:00am
the prop turns evenly with no binding spots, i'll pay attention to fuel delivery.
