  New Posts New Posts RSS Feed - shaft packing
shaft packing
techna2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote techna2001 Quote  Post ReplyReply Direct Link To This Post Topic: shaft packing
    Posted: July-10-2007 at 12:44am
so i replaced the Flax rope and check it 6 or 7 times over the day.. at first i had a drop or 2 every second.. but about 2 hours later i never saw any drops.. but the bilge water never seemed out of control.. after 6 hours or so of riding had 1 inch in the bottom..
while reading on here.. a few people said that the nut should not get hot.. so that was one thing i checked.. it was warm.. not hot.. i could touch it and it stayed that way threw the day.. i was warmer then my skin i could feel the heat off it..but should it be cold... or is warm ok...
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 1:05am
warm is fine and your really not going to see it drip unless it is rotating I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote techna2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 3:59am
i was making dad drive and i was looking at it... so it was spinning...
thanks
Mickstique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mickstique Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 9:47pm
where do you purchase the Flax rope?
"wake" up!
80Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2007 at 9:54pm
You can purchase at www.skidim.com . They also have the GoreTex grade as well.
1980 Ski Nautique , Ford 351W Commander, BW Velvet Drive 1:1
Dayton Ohio
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2007 at 10:06pm
In the summer, the engine and transmission heat up that fitting more than the friction. The water temp the other day was 91 Deg F when I checked this out.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
