Sparking and starting but no key |
Spievy
Senior Member Joined: June-09-2007 Location: United States Status: Offline Points: 105 |
Posted: August-07-2007 at 2:16pm |
It appears I am cluttering the forums today...sorrry, but when out this past weekend after an oil change boat seemed to be running great. Let the wife cruise for a while.....turned out to be a big mistake. I met up with her from a friends boat with our boat off. She mentioned it had made a strange sound just before turning it off. She described it as the engine revving than going really low so she shut it down. I got in got three really slow cranks then absolutely nothing. So my thoughts were alternator or battery. Battery is brand new so I was pretty definate on the alternator. Had a friend hook up cables with me on his 79 for about ten minutes, still nothing not even a weak crank, or needles moving, etc. He towed me in. Put the charger on at home and every time I plugged it in it kept spiking up and down and sparked hard when I pulled the positive on and off....more than it should normally. I immediately removed from the boat and put on the charger by itself and sure enough it was dead (alternator?). After a good charge when trying to reconnect to the boat it would crank the engine and spark everytime. I removed the key still the same thing. My thoughts were igition switch, starter, voltage regulator? Any help would be appreciated.
1968 Mustang 318 CM
Get the volt-ohm meter out! Something is keeping power going to the starter. It could be all the things you have mentioned. Check the solinoid first to see if it's contacts are welded together and if not see if it is getting power to it's coil. Work your way back from there.
Edit: If you need it, you can find the wiring diagram in the ref section under the Chysler V8 manual on about page 36. |
Spievy
Got it, thanks. I will send back my findings.
1968 Mustang 318 CM
Spievy
I printed that page!! That's what I needed , thanks as always.
1968 Mustang 318 CM
Spievy
I have an update on my post. I was able to put a good charge on my battery, put the key in the on position and put cables to battery, which started the boat. Turned key off and starter continued spinning. Would this indicate a relay and/or starter replacement? Relay he indicated could be stuck in the "on" position? I was told this by a mechanic as a possibility. It is difficult to check voltage with and ohm/volt meter considering connecting the battery starts the boat?
Possibly voltage regulator? He was not sure since it is a boat and the year of the motor and it's set-up. |
1968 Mustang 318 CM
Don't connect the battery. Check the relay/solinoid first to see if the contacts are welded - The big terminals. You could also disconnect the power to the starter, wrap some tape around the lug then connect the battery up and check it.
Spievy
Got it. The mechanic is family and he was trying to help eliminate possibilities and time by just replacing the relay, but it does not sound like his idea is right for the application. I will follow the above mentioned. Thank you for the correct approach, I am guessing it has been some time since he has worked with electrical (not a current mechanic), but does know older style engines pretty well. Will be helping me with replacing or rebuilding the fuel pump I mentioned in a separate post.
1968 Mustang 318 CM
