  New Posts New Posts RSS Feed - 1994 PCM351 HO 285hp engine for sale
righterjc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote righterjc Quote  Post ReplyReply Direct Link To This Post Topic: 1994 PCM351 HO 285hp engine for sale
    Posted: October-04-2004 at 8:38pm
complete 1994 351HO engine from top to bottom & front to back. needs #2 valve replaced and has a very very very small chip on #2 piston,ProTec management system, manifolds, holly carb, was running great but needs new valve, gt40 heads,800 hrs, $1400 or obo
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2004 at 7:44pm
whats your location?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote righterjc Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2004 at 8:44pm
Engine is located in Orange County, California
For more info you can call me at 714 745-3267
diamndmanusa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diamndmanusa Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2007 at 1:18pm
Hello
would you have a console for a 90-93 Ski Nautique or a Barefoot 91-94?
buddysproject View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote buddysproject Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2008 at 7:53pm
I know it's been a while since you posted this. But is your engine still available? I finally got a chance to pull mine and take a look at what was wrong, and it's just time to replace it. Thanks.
Gregg
"If it can't be done in, on, or behind a Nautique it isn't worth doing."
Gregg 1987 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2008 at 8:12pm
Gregg, that motor wont work for you- its a LH rotation motor. You need a RH unless you want to reindex the tranny and switch to a LH prop. That opens a whole 'nother can of worms with driveability issues.
