? about a Ford front dampner
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=13957
Printed Date: June-06-2024 at 12:28pm
Topic: ? about a Ford front dampner
Posted By: Gary S
Subject: ? about a Ford front dampner
Date Posted: June-09-2009 at 10:26pm
Does anyone have a picture of a right hand rotation dampner? Are they different between right hand rotation and left hand, meaning timing marks? I'm thinking I have a standard left hand rotation one. Here's a pic, the tape was added so I could see the marks and it matches the ones stamped into it,but the more I think of it,they seem backwards. Any thoughts?
Posted By: BuffaloBFN
Date Posted: June-09-2009 at 10:43pm
I think it should be exactly bacerds.
Posted By: SUNAPEE CROW
Date Posted: June-09-2009 at 11:12pm
That is right , they are backwards. I bought the Summit universal small block Ford and marked the 12 degrees or whatever on the other side of zero and ran with it. I have been happy. The elastomer or whatever between the rings of the damper will deteriorate over time and the damper itself will go out of balance. Crazy vibes at 1500-2000 RPM.
Date Posted: June-09-2009 at 11:14pm
Gary,
I think it's backwards too. The degree markings are after TDC.
You could always read them in a mirror!!
Posted By: Gary S
Date Posted: June-10-2009 at 1:00am
The good Doctor called early this evening ,sure enough it's a left rotation dampner. No problem with that, I just need to get a timing tape that has the degrees on both sides of TDC. Thanks guy's
Date Posted: June-11-2009 at 3:33pm
Gary, my '71 has a LH damper as well- its gotta be original. Threw me for a loop the first time I set the timing! Just put the tape on backwards- TDC is still in the same spot, obviously.
Date Posted: June-11-2009 at 4:19pm
TRBenj wrote:
Gary, my '71 has a LH damper as well- its gotta be original. Threw me for a loop the first time I set the timing! |
I'll bet that was fun. I bought a LH but knew I was doing it, so I just transfered the marks. This was on my '79 and the counterweights were the same.
It's running good...how can it be 20 degrees off?!!?
Posted By: Gary S
Date Posted: June-12-2009 at 2:11am
When I bought the tape I didn't get to see it first and had thought they would just put the marks before and after TDC. Not thinking I put it on when I did the heads. Just put in a new set of points and in the back of my mind it's saying somethings not right. Knowing the original 289 block had been changed to a 302,I thought they must have used an automotive dampner,now who knows
