351 carb engine schematic
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=16583
Printed Date: May-03-2024 at 2:48pm
Topic: 351 carb engine schematic
Posted By: Texasttk55
Subject: 351 carb engine schematic
Date Posted: February-18-2010 at 12:41pm
I was hoping that someone might have an electronic copy of the engine schematic for a Ford 351 carb engine. I have 99 sport nautique and it seems to be having fuel delivery problems. It started and idled for about 10 minutes but then suddenly stalled out. When I tried to restart it, it would only start and run will using starting fluid. It seems that no fuel is getting to the carb.
Any advice will be greatly appreciated. I'm new to working on boat engines and didn't want to order the new fuel pump before getting some veteran advice.
Thanks, Travis
Date Posted: February-18-2010 at 1:22pm
Travis,
If you feel it may be a fuel pump issue, "T" a pressure gauge into the line before you go and order a pump. See what the existing pump is doing.
Posted By: SUNAPEE CROW
Date Posted: February-18-2010 at 1:37pm
Take a quick look at the filter that is built into the fitting where the gas line goes into the carb. It can plug and create the symptom you are describing.
Posted By: kapla
Date Posted: February-18-2010 at 1:39pm
try the reference section, here, there are manuals from many years...if not the same the closest one will suit you...fuel system is quite the same in the 351w...
Date Posted: March-09-2010 at 12:45am
Ok so I have checked spark and it seems very strong. Checked vacuum at the bottom of the fuel pump, it also seems strong.
The only thing that I cant check is fuel pumping out the top of the pump into the carb because I can't seem to losen th efitting running from the hard line into the bottom of the carb.
Is there a trick to this without bending that fuel line? Also if fule is in the line can it be assumed that the top side of the pump is working? I can see fuel spray into the carb when I manually push the throttle cable and when the actual throttle is pushed forward. The engine fires up but only runs for a split second. This seems like a fuel delivery issue but I cant figure out were the problem is occurring.
Any ideas? Thanks for the advice.
- Travis
Posted By: boat dr
Date Posted: March-09-2010 at 12:57am
Do you have a safety lanyard, or kill switch.The effects of this switch in the off position will be the same as you describe.
Sounds like you are loosing power to the coil after the release from start mode.Try a jumper wire directly to the coil this will bypass all switches and safety systems.
Leave the carb and fuel system alone till you resolve possible problems with ignition..........
------------- boat dr
Posted By: Waterdog
Date Posted: March-09-2010 at 9:58am
Texasttk55
Sounds like the ignition has power when the key is in crank and not in run.
------------- - waterdog -
Date Posted: March-09-2010 at 10:58am
Another call for the good old multimeter!!
Posted By: 79nautique
Date Posted: March-09-2010 at 11:11am
HHHMMMM it's 99 wouldn't the fuel control cell's and the relay's be a better place to start than the ignition?
Posted By: bubbaskier
Date Posted: March-09-2010 at 5:38pm
Anti-Syphon Check Valve
Somewhere from the fuel tank to the fuel pump should be an anti-syphon valve. On my 1984 SN2001 the valve is on the fuel tank. This valve allows fuel to flow in only one direction. Find the valve, remove the valve and see if there is any debris in the valve restricting the flow of fuel. I have had to clean mine once in sixteen years. Also the springs in these valves do wear out allowing the gas in the fuel line to syphon back into the tank causing starting problems, ie: lack of fuel.
Date Posted: March-09-2010 at 5:55pm
Somewhere from the fuel tank to the fuel pump should be an anti-syphon valve. On my 1984 SN2001 the valve is on the fuel tank. This valve allows fuel to flow in only one direction. Find the valve, remove the valve and see if there is any debris in the valve restricting the flow of fuel. I have had to clean mine once in sixteen years. Also the springs in these valves do wear out allowing the gas in the fuel line to syphon back into the tank causing starting problems, ie: lack of fuel. |
Corky,
Welcome to CCfan. Tell us more? Boat?
Now, you actually have the operation of the anti-siphon valve backwards. No big deal as I was corrected once as well. The anti-siphon is there so if there is a break in the fuel line from the tank to the fuel pump, you won't fill up the bilge with gas. It checks the siphon but isn't stong enough to check the pull from the fuel pump. Gas siphoning back to the tank is prevented by the internal check valves in the pump itself.
Date Posted: March-09-2010 at 7:39pm
Thanks for the correction on the syphoning. I won't jack the thread; I will post some details of me on a new thread sometime this spring when it warms up and I can get some pictures.
Posted By: boat dr
Date Posted: March-09-2010 at 7:55pm
bubbaskier, welcome to the site.Great place to learn and to share the do's and don'ts of inboard boating.
But be forwarned as to info you post,"my brother told me" and " I heard you could do it that way" are not valid here.
You will be called out on misinformation, and applauded for that little short cut you dicovered.Please share, pics ,info,listing for junkers and all CC issues...........Billy
Date Posted: March-10-2010 at 1:42pm
The boat will continuously run with the addition of starting fluid but as soon as I stop using it the engine dies. This seems to indicate a fuel issue correct?
It just seems odd because I can see fuel going to the carb so it really isn't adding up but Ill check the coil with a mulitmeter.
Date Posted: March-10-2010 at 1:47pm
If it runs with starter fluid, then youre correct- you have a fuel delivery problem. You can put away the multimeter... for now!
Where are you seeing fuel going to the carb? Hopefully you dont have a rubber hose with an inline filter between the pump and the carb... thats a big safety no-no.
Pull the flame arrestor and work the carb by hand- if it sprays fuel when you advance the throttle, then youve got gas. If that wont keep it running, then Id say you have bad gas. If you dont have gas, then you need to trace the problem back to the source. The 2 likely culprits would be a bad fuel pump, or a blocked fuel line (look at the antisiphon valve first).
Posted By: DrCC
Date Posted: March-10-2010 at 3:06pm
Trick for the "hardline" at the carb.
Line wrench
1" wrench or maybe a cresent
PB Blaster
and possibly a small hammer
Date Posted: March-10-2010 at 3:23pm
I can see fuel spraying into the carb when I work it by hand at the carb as well as when I advance the throttle. Things seem to be pointing to more of a fuel issue.
Just to recap when this problem first occured a few weeks ago I was taking the boat out for the first time in 2 months and before launching I added about 10 gallons of fresh fuel. The boat started and idled for approx 5 min and then abruptly died. Since then this starting and quickly dying (within 2 seconds)problem has persisted.
Date Posted: March-10-2010 at 3:25pm
When working the carb by hand, is there anything you can do to keep it running?
If not, and you have a good supply of gas, it sounds like you have bad gas. Smell it- bad gas smells like paint thinner.
Date Posted: March-10-2010 at 3:38pm
Line wrench
PB Blaster
and possibly a small hammer |
leave the hammer for your head and not the carb.
the trick is tightening the flare nut slightly before loosing it, 5/8 line wrench for the fuel line, 1" line wrench or open end to hold the carb's fitting, once the line is loose then use a 6 point socket or a 1" line wrnch to remove the other fitting put that is only if your replacing the filter if not there's not a need to remove it from the carb.
Date Posted: March-10-2010 at 3:42pm
i would suggest disconnecting the fuel pick-up hose at the fuel pump suction side, hose that goes to the fuel tank. Get a new section of hose, attach to the fuel pump, stick the other end in a a fresh jug of fuel and then start the boat might have to help it alone until the old gas is out of the fuel bowl and fuel line but then it should take off and run by it's self after a minute or two, if it does, it's a vent issue or siphon valve issue or bad gas or both.
if it still won't run then it's most likely the fuel pump.
Date Posted: March-10-2010 at 4:58pm
Ill check those options tonight. Thanks for the info.
Date Posted: March-10-2010 at 5:04pm
Anyone know the diameter of that hose off hand (connecting to the bottom of the fue pump)? Id like to pick it up on the way home from school today.
Date Posted: March-10-2010 at 5:06pm
by bypassing the tank you take problems at the tank out of the equation and narrow it to the fuel pump or carb. Another think to check is if there is a filter between the pump and carb, and this encludes one that might be in the carb, but they need replaced this can cause a flow issue as well as that is what seems like your problem is.
Date Posted: March-10-2010 at 5:08pm
think the hose is 5/8" fuel line or maybe it's 3/8" Tim where you at?
Date Posted: March-10-2010 at 5:24pm
The feed line going to the fuel pump is 3/8" ID.
Date Posted: March-10-2010 at 5:41pm
Great, thanks Ill pick some up this afternoon.
Date Posted: March-10-2010 at 11:26pm
So i pulled the line at the bottom of the fuel pump and put a new one on which I ran in to a fresh gallon of fuel. It hiccuped a bit but then started to run fine. The only problem was it died when put in neutral.
This may be an effect of not running enough good fuel through yet it but either way the old fuel did smell like paint thinner so that was at least part of my problem. Any advice on draining 20gal of fuel?
Once again thanks for the great advice.
Date Posted: March-11-2010 at 1:08pm
Id siphon it out of the tank and into some empty gas cans. Id run the boat a little while with fresh gas before you make any changes- the carb was full of the old junk, so Im sure theres still some of the old stuff in there.
Posted By: Hollywood
Date Posted: March-11-2010 at 1:14pm
Whoever takes drain oil might take your old gas too. There are couple garages around here who run waste oil heaters, we get landscaping services in return for our oil! The solution to pollution is dilution.
Date Posted: March-11-2010 at 1:31pm
use a can off carb cleaner in the gas to help loosen up the junk in the fuel bowl.
Date Posted: March-11-2010 at 1:38pm
I run a can of "Sea Foam" through my 1984 SN2001 every 50 hours. I also use "Sea Foam" as a stabilizer when I winterize my boat. Personal experience has made me a huge fan of the product.
Date Posted: March-13-2010 at 12:49am
Good news. Siphoned the old gas-it looked like a milkshake- cleaned the carb with sea foam and run a lot of fresh gas with additional sea foam through it yesterday and today. Its running great and seems to be back to normal.
Thanks again for all the help and useful advice.
- Travis
