Cool Carburetor Tool and Fixed Fuel Line Leak
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27143
Printed Date: May-03-2024 at 8:09pm
Topic: Cool Carburetor Tool and Fixed Fuel Line Leak
Posted By: Bri892001
Subject: Cool Carburetor Tool and Fixed Fuel Line Leak
Date Posted: July-24-2012 at 1:12am
Hi All,
I found this tool online: http://www.mactools.com/shoponline/product/tabid/120/p-319926-rochester-carburetor-wrench.aspx" rel="nofollow - Rochester Carburetor Wrench
The link changed, this should be the same thing here: http://www.mactools.com/en-us/Wrenches/Open-End-and-Angle-Wrenches/DA32/SAE-Angle-Wrench-1" rel="nofollow - http://www.mactools.com/en-us/Wrenches/Open-End-and-Angle-Wrenches/DA32/SAE-Angle-Wrench-1
It's advertised as being for Rochester Carburetors, but it had two 1" ends at different angles. I found it very useful for the fuel bowl to line adapter fitting on my Holley. I was having a hard time finding a 6 point, 1" line (flare) wrench. I figured the 4 points would be close enough, and it was. It gives good maneuverability too.
Date Posted: July-24-2012 at 1:17am
Date Posted: July-24-2012 at 1:30am
Before it started leaking badly, it was tough to see where it was coming from. So, it was almost good that it got worse.
I was able to use the carb wrench and a couple other tools, to remove the adapter fitting, replace the gasket, and tighten it down good. It stopped leaking.
Date Posted: July-24-2012 at 8:29am
Brian, Nice write up!
Posted By: The Dude
Date Posted: March-20-2019 at 9:17pm
is there a gasket between the line flare and the fuel bowl adapter? Or is the gasket between the adapter and the housing?
http://www.correctcraftfan.com/diaries/details.asp?ID=717&sort=&pagenum=1&yrstart=1991&yrend=1995 - 95 Sport
Posted By: KENO
Date Posted: March-20-2019 at 9:46pm
Same answer as your other post
