Rebuild water in intake?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=27332
Printed Date: April-29-2024 at 11:33am
Topic: Rebuild water in intake?
Posted By: Oleeolson
Subject: Rebuild water in intake?
Date Posted: August-05-2012 at 11:50pm
Just rebuilt 1985 351w ran great till some how water started entering intake? Now have water in all cylinders but none in oil pan? Had the home hose hooked up did I blow some gasket out?? What would be the cause?
Posted By: GlassSeeker
Date Posted: August-06-2012 at 1:37am
once in cylinders it will be in oil pan.
I would think head gasket
------------- This is the life
Date Posted: August-06-2012 at 6:59am
I believe it was Eric that reported he's had issues with the intake manifolds cracking near the T stat housing. Check it out with one of the dye crack checking systems.
No, running the engine on the hose didn't do it.
Posted By: eric lavine
Date Posted: August-06-2012 at 7:52am
that was me Pete. that way fills the block though. is it water on both banks or just one side?
Date Posted: August-06-2012 at 9:14am
eric lavine wrote:
that was me Pete. that way fills the block though. | Yup, I couldn't sleep and the coffee hadn't kicked in yet!
Eric, What's up with you? still working on the BIG stuff?
Date Posted: August-06-2012 at 11:41am
there was water on every spark plug both sides cant imagine where it is entering will do a compression test on all the cylinders tonight but I dont think its blown head gaskets, as its every cylinder both sides
Posted By: Bri892001
Date Posted: August-06-2012 at 2:49pm
I believe it was JoeinNY that did describe a scenerio where running it off the hose could cause this condition. But it was related exhaust manifolds.
If I remember correctly, running off the hose force feeds water into the motor. This is basically fine (albeit you can't test your impeller).
The situation happens when water is getting through the engine, but the engine is not running. Normally, for water to get up near the exhaust manifolds, the engine is running, and is kind of blowing out the water as it goes. When it is not running, but the manifolds are getting water anyway, the water can seep in through the exhaust.
Keep in mind, the manifolds have to be bad anyway for this to happen though.
Date Posted: August-06-2012 at 3:02pm
If the manifolds (or riser gaskets) are bad, then you dont need to be running on the hose for water to work its way into the cylinders. As soon as the engine shuts down, water can leak in.
Date Posted: August-06-2012 at 4:49pm
Know I'm thinking back and re thinking this - the boat back fired and seemed like it reverse rotated for a second or 2 because it blew fuel out the carb wondering if it sucked in water then? But that wouldn't explain why it was running so bad but could explain the water. When I first put the boat in and ran it, it was running perfect then just kept getting worse and worse. The only thing I can figure if the other issue is unrelated is maybe a gas issue? Any way to check fuel pressure? without buying a gauge?
Posted By: BuffaloBFN
Date Posted: August-07-2012 at 1:28am
Oleeolson wrote:
Just rebuilt 1985 351w |
Stock parts? And water was inside the intake runners?
Date Posted: August-07-2012 at 10:55am
Oleeolson wrote:
Know I'm thinking back and re thinking this - the boat back fired and seemed like it reverse rotated for a second or 2 because it blew fuel out the carb wondering if it sucked in water then? | That certainly wouldnt be the first time a motor has spun backwards for a rotation or 2 and sucked water into the cylinders. I know a few people here who have done it. Still dont have a great explanation as to why it happens, but it does happen!
