need help..installation of a skylon pole
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2800
Printed Date: May-23-2024 at 1:55am
Topic: need help..installation of a skylon pole
Posted By: Guests
Subject: need help..installation of a skylon pole
Date Posted: December-15-2005 at 6:13pm
can someone PLEASE help!...i just recently purchased a skylon extension. bought it off e bay, and have no idea how this connect to boat..close up pics would be great.. really confused on how this connects to front of boat..thanks
Posted By: bkhallpass
Date Posted: December-15-2005 at 9:05pm
There should be a heavy nylong ring with the kit. Slide it through the bow eye so that you have a loop in each hand, and the strap is double wide through the bow eye (not the lifting ring, the bow eye which you hook to the trailer). Now both ends that you have in your hand attach to the cable which runs from the pole. There is probably a caribiner to hook the strap into.
Go to the following post where chavonbravo has posted a pic of his setup. You should get the idea: http://correctcraftfan.com/forum/forum_posts.asp?TID=2744&PN=2&TPN=1
BKH
Posted By: 882001
Date Posted: December-15-2005 at 10:13pm
<img src="http://www.correctcraftfan.com/diaries/images/163/DSC00046.JPG">
------------- kemah texas
http://www.correctcraftfan.com/diaries/details.asp?ID=163&yrstart=1986&yrend=1990 - 1988
skinautique "2001"
Posted By: 882001
skinautique "2001"
Posted By: The Dude
Date Posted: December-16-2005 at 6:48pm
Hey 88,
Where do you put in most of the time? I'm in Friendswood. Where's your trailer from?
http://www.correctcraftfan.com/diaries/details.asp?ID=717&sort=&pagenum=1&yrstart=1991&yrend=1995 - 95 Sport
Posted By: 882001
Date Posted: December-17-2005 at 10:39am
havent had the boat out since rita evac.
we put in at walter hall mostly. that sport is sweet. almost bought a 98 air
last year, but didnt wanna go from no payment to having a payment. but should
of, it was an awsome deal, but my boat is fine just a little small.havent had the boat out since rita evac.
skinautique "2001"
Posted By: Guests
Date Posted: December-21-2005 at 2:47pm
thanks guys...now that i have played around with it, its pretty simple..
Posted By: 882001
Date Posted: December-21-2005 at 3:57pm
i hook mine to the lifting ring. about 50% will tell you its a bad idea. but havent heard of any ill effects, the boat is built like a tank. and mine has not had any problems at all
skinautique "2001"
Posted By: Dank
Date Posted: December-22-2005 at 9:08am
I hook mine to the lifting ring as well.
------------- "I don't know what the world may need, but a http://correctcraftfan.com/diaries/details.asp?ID=886&sort=&pagenum=1&yrstart=1986&yrend=1990" rel="nofollow - V8 engine's a good start for me"
Posted By: Rick
Date Posted: December-27-2005 at 7:54pm
Ryan before you put it over your pylon make sure you have the right mesh sleeve. It is either white or yellow depending on the pylon I beleive all CC use the white Let me know if you need some I may have some left.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=250&yrstart=1996&yrend=2000%20" rel="nofollow - 2000 Ski
Posted By: chavonbravo
Date Posted: December-27-2005 at 11:00pm
I got mines off ebay, and they only had the red mesh...boy was that hard to get on. had to kinda hammer the pylon down. Also, my top portion swivels a bit while underway. Wouldn't really be noticeable except that with a wakeboard rack, you can tell when the wakeboards are like 45 degrees off to the side. :)
Posted By: Guests
Date Posted: December-29-2005 at 7:04pm
rick i actually do not have that mesh, i didnt know you had to have it...makes sense i put the bottom portion on and it was very sloppy..if you have some i cloud send you some cash..or even where could i purchase the mesh if you can't come up with any..thanks again guys for the advice.
Posted By: 87martinique
Date Posted: March-19-2006 at 1:03pm
I just got a Joystick pylon and need to find the insert. Rick do you know if the yellow insert is thinner then the white insert. There was a white insert on my pylon when i bought the boat but it is too tight for the pylon to slip over.
Posted By: 05 210
Date Posted: March-19-2006 at 2:28pm
The yellow insert is smaller and the only one that would work on my 98 air tique.The red & white ones were too big.That mesh is the same stuff they use to protect machined metal parts.If you know someone who is a machinist or sells machining equip.,they can get you a roll for next to nothing.I also used my lifting ring,but if it's not adjusted properly(i.e.the turnbuckle under the bow)the ring can move around when pole is loaded and you'll damage the gelcoat.hope this helps.
