Circuit Breaker Question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=28680
Printed Date: May-08-2024 at 3:02am
Topic: Circuit Breaker Question
Posted By: AAM196
Subject: Circuit Breaker Question
Date Posted: January-07-2013 at 5:10pm
On a 1999 SN, My 20amp ign breaker button gets stuck a bit and you have to muscle it... I plan to add a heater but noticed there is a breaker set up for a shower that I will never add. Is that a 20 amp breaker or 10amp?
is the breaker I need part # S5925?
Posted By: phatsat67
Date Posted: January-07-2013 at 5:16pm
Andy, That is the correct part number for a 20 amp breaker. I'm not sure what the factory amp was on a shower circuit.
Date Posted: January-07-2013 at 9:35pm
Andrew, With this heater you want to add, I hope the load you want to add is for a blower motor and not for an electric heating element.
Understand that it takes plenty of amps to create heat. As an example, 10 amps equals 120 watts. 120 watts is only 409 BTU's. That's not much!!
I suggest you take a look at the load in amps and see what's available.
Posted By: AAM196
Date Posted: January-08-2013 at 12:10am
Peter, Understood.... I was planning to install a Heatercraft style (not electric) and the blower is said to draw 8.5 amps on hi.
I think there are 10 amp breakers in place for a heater and shower option but I have not actually checked the rating on them.
Date Posted: January-08-2013 at 8:02am
AAM196 wrote:
Peter, I think there are 10 amp breakers in place for a heater and shower option but I have not actually checked the rating on them.
| Andrew, Yes, go this route since it's best to use the already existing prewired wiring.
