shallow lake
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=3020
Printed Date: May-16-2024 at 7:21pm
Topic: shallow lake
Posted By: floppy
Subject: shallow lake
Date Posted: February-12-2006 at 7:15am
how shallow of water can you safely drive in. thanks
Posted By: mars88
Date Posted: February-12-2006 at 3:41pm
It depends on the type of boat. We have an 88 ski and with a 2 foot draft,I think? Not sure but i think that means you can run full power in 2 foot of water. We live on a pretty shallow cove and have no problem just idling. I wouldnt dare to test my luck tho!
------------- mars
Posted By: floppy
Date Posted: February-12-2006 at 4:44pm
thanks mars, I just purchased an 86 ski nautique and was in the process of installing an hdr600 depth finder and was wondering what to set the alarm for? where i ski mostly the only pier is at the boat ramp, so i will be docking alot at the bank. with my old outboard you could just trim up. so i am a little bit nervous about it.
Posted By: jameski
Date Posted: February-12-2006 at 5:00pm
I keep my alarm set at 10' and it doesn't get too annoying. If I set it lower, it will probably be too late to correct my course before I run aground. If I'm going to anchor near an unfamiliar shore, I approach very slowly until I reach 3' then I anchor and walk.
------------- current boat
http://www.correctcraftfan.com/diaries/details.asp?ID=1977 - 94 Sport Nautique
previous boat
http://www.correctcraftfan.com/diaries/details.asp?ID=601 - 78 Martinique
Posted By: floppy
Date Posted: February-12-2006 at 5:14pm
thanks thats what i needed to know.
Posted By: Tim D
Date Posted: February-13-2006 at 6:01am
Two things about running in shallow water, kicking up sand will nick the prop and shorten the life of your impellor. And sandy water will cause the strut bushing to wear quicker.
------------- Tim D
Posted By: Jim_In_Houston
Date Posted: February-13-2006 at 6:08am
Running in shallow water will bend your prop shaft and break your prop. The resulting extreme vibration will then cause your engine to blow a head gasket - take my word for it.
------------- Happy owner of a '66 and a '68 Mustang
Posted By: 82tique
Date Posted: February-13-2006 at 10:48am
I have my alarm set at four feet....haven't hit anything YET (knock on wood)
------------- Life is Good.
