Block heater caution
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=32688
Printed Date: May-05-2024 at 4:59am
Topic: Block heater caution
Subject: Block heater caution
Date Posted: January-17-2014 at 10:38pm
For those of you who live in colder climates and use a block heater I have to caution you about getting shocked. This has happened to me a couple times and then again last night plugging the diesel in. Coming home, the roads were wet with water and salt. I was plugging it in and got a pretty good shock. Evidently the salt water on the plug and connector is enough to conduct electricity!
Posted By: GlassSeeker
Date Posted: January-17-2014 at 10:47pm
That's just too cold, I would have to hibernate.
------------- This is the life
Posted By: Gary S
Date Posted: January-17-2014 at 11:34pm
I always had mine on a timer so it was off when I got home to plug it in.This by the way is on my Jeep,since I was so close to work I thought it was best for the engine and for me too. My VW I would turn on 2 hours before I had to leave,the Jeep being inside about 1 3/4. I suppose a V8 takes longer to heat up?
Date Posted: January-18-2014 at 8:50am
Gary S wrote:
I suppose a V8 takes longer to heat up? | Gary, GM only put a 650 watt block heater in their 6.5. That's not much when the wind is blowing and the temp is low so I just keep it plugged in when it's in the driveway.
