Alternator Output
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=35682
Printed Date: June-06-2024 at 12:52pm
Topic: Alternator Output
Posted By: Jonny Quest
Subject: Alternator Output
Date Posted: April-01-2015 at 11:29pm
I've got a 3 year old ARCO alternator (Model #60050) in my 1994 Ski Nautique with Pro Boss engine.
The voltmeter shows 14-15V when the engine is running. I thought that the gauge might be bad (20 years old), so I put in a new voltmeter. Same. 14-15V wen engine is running.
Is that too much?
Date Posted: April-02-2015 at 12:19am
Rob, The 15 is on the high end but 14 would be normal especially if the battery needs charging. What kind of battery do you have? Hopefully it's NOT a deep cycle!. I do suggest you go and purchase a $18.00 VOM BEFORE and test first before just replacing a gauge thinking it's bad.
Date Posted: April-02-2015 at 1:56am
8122pbrainard wrote:
...Hopefully it's NOT a deep cycle!.
I do suggest you go and purchase a $18.00 VOM BEFORE and test first before just replacing a gauge thinking it's bad. |
Battery = Optima (non deep cycle) VOM Test First = You are correct. I should have purchased a tester...but I spent $35 on a new voltmeter, betting that the 20 year old gauge is bad.
Posted By: MustangMadness
Date Posted: April-02-2015 at 9:53am
14.5v is normal above idle, but I would recommend a load test on the battery especially if it is the original (1994).
------------- I like a 6' beam on a small lake... My Muscleboat 1975 Mustang 225 307RH
Posted By: phatsat67
Date Posted: April-02-2015 at 10:36am
The newer style Mando alternator usually outputs around 14.5 the older style Motorola always outputs around 13.5
