Boat lift cable busted.
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=38885
Printed Date: April-28-2024 at 6:08pm
Topic: Boat lift cable busted.
Posted By: seacamper
Subject: Boat lift cable busted.
Date Posted: June-02-2016 at 11:27pm
Hey Guys, Anyone replace a boat lift cable? I have a Craftlander, and the thing just let go tonight. Hard? Easy? Any tips?? Tom
------------- 1980 Ski Nautique Boat Bar 1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft
Posted By: jbear
Date Posted: June-02-2016 at 11:44pm
don't know a thing about them but am willing to help if you need me...betcha Eddie will say the same.
john
Posted By: Air206
Date Posted: June-03-2016 at 12:01am
Is it an overhead cable system... I've done that. We can chat.
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Date Posted: June-03-2016 at 12:12am
john | That's because you two are my boatfriends. Thanks Jbear, I will let you know! Tom
Date Posted: June-03-2016 at 12:15am
Air206 wrote:
Is it an overhead cable system... I've done that. We can chat. | No, its one of these: http://www.nucraftonline.com/boat-lifts/vertical-lifts/" rel="nofollow - Craftlander
Posted By: Air206
Date Posted: June-03-2016 at 12:22am
We can still chat - but I'll be useless as usual! Ha!
Posted By: quinner
Date Posted: June-03-2016 at 10:14am
First thing is DO NOT buy the cable on EBay, my neighbor did that and it snapped on the very first lift. Be sure and get a good quality cable from a reputable source. If the end(s) have any special connectors you are probably best off going OEM parts. Not familiar with that brand lift but have changed out various cables on Shorestation brand vertical lifts and it was all pretty simple, would imagine the same will hold true for yours.
Date Posted: June-03-2016 at 10:19am
Tom, All I can add is check out why the cable snapped. Bound up sheaves? Frayed from rubbing? Did the cable come off any of the sheaves? Overload? Cable corroded?
Posted By: gun-driver
Date Posted: June-03-2016 at 12:17pm
Seems to me that you seem to be "cable challenged " first the steering cable now the lift.
Date Posted: June-03-2016 at 1:44pm
8122pbrainard wrote:
Tom, All I can add is check out why the cable snapped. Bound up sheaves? Frayed from rubbing? Did the cable come off any of the sheaves? Overload? Cable corroded? |
So far from what I could see of the broken cable, it was corroded. I am just at the 2 year mark on the lift, so when the new part comes, (I ordered OEM) I will make sure and check it out. Craftlander was pretty easy to work with, and they got my parts in the mail today. Overall, I am happy with the lift.
Date Posted: June-03-2016 at 1:47pm
gun-driver wrote:
Seems to me that you seem to be "cable challenged " first the steering cable now the lift. | This is the story of my life. If I can put it in backwards, I will. Anything that I have that is supposed to slide in a tight space needs massive amounts of lubrication or it wears out. It is getting really old.
Posted By: tryathlete
Date Posted: June-03-2016 at 1:54pm
"Anything that I have that is supposed to slide in a tight space needs massive amounts of lubrication"
Sounds like a good problem to have!
Posted By: quinner
Date Posted: June-03-2016 at 2:15pm
When you say 2 years, did you buy it new?? If so that is a problem, you should easily get 10yrs on a cable, double that if you are Pete :)
Posted By: Hollywood
Date Posted: June-03-2016 at 2:28pm
2 years for scamper is probably equal to 10 years for you. They ski every day, all year...
Date Posted: June-03-2016 at 9:46pm
| It was at least 25 years before a new cable was needed on my lift! I replaced it with a stainless so I should get 50 years out of it!!
Posted By: Gary S
Date Posted: June-03-2016 at 10:27pm
I know you know what your doing but I have been told from several sources not to use stainless,it can't take the bending being wound up on a drum
Date Posted: June-03-2016 at 10:31pm
Gary S wrote:
I know you know what your doing but I have been told from several sources not to use stainless,it can't take the bending being wound up on a drum | Your sources don't know their wire rope!! I used 6 × 37—IWRC Core stainless!
Date Posted: June-04-2016 at 12:35am
Here is a pic: http://s266.photobucket.com/user/turninggrey/media/IMG_1176.jpg.html" rel="nofollow">
Date Posted: June-13-2016 at 10:13pm
Well, it was pretty easy. I jacked it up with a cum-along, and threaded the cable no problems. It simply goes through two pulleys that were spinning just fine. I guess I will inspect them in a couple months to see how they are doing.
Date Posted: June-14-2016 at 12:01am
seacamper wrote:
This is the story of my life. If I can put it in backwards, I will. Anything that I have that is supposed to slide in a tight space needs massive amounts of lubrication or it wears out. It is getting really old. |
seacamper wrote:
I jacked it up with a cum-along, |
Date Posted: June-14-2016 at 12:04am
gun-driver wrote:
seacamper wrote:
I jacked it up with a cum-along, | |
Good catch.
Date Posted: June-14-2016 at 12:10am
You know, I meant the first post about lubrication as a joke, but I actually misspelled come along. I googled it, and came up with cumalong, then spell checker gave me cum-along.
Date Posted: June-14-2016 at 12:16am
Maybe you're using Google.HK or Thailand? I cannot find cum-along anywhere other than at Quinner's house.
Come-along, cable winch hoist, ratcheting winch--anything seems fine as long as there's no cum along with it.
Date Posted: June-14-2016 at 4:09pm
| Here is what popped up when I googled "cumalong" because I did not know how to spell it:
http://www.cooperindustries.com/content/public/en/power_systems/products/kearney_tools_connectors/power_line_tools/cumalongs.html" rel="nofollow - http://www.cooperindustries.com/content/public/en/power_systems/products/kearney_tools_connectors/power_line_tools/cumalongs.html
Since that popped up, I thought "cumalong" was the correct spelling. When I typed it in, my computer's word check turned it red. When I right clicked it, I got "cum-along" and the computer corrected it.
Now, if you are calling me a fu<king liar, please PM me so we can get together, and have you say it to my face. If we are just having fun, then fine.
Date Posted: June-14-2016 at 4:15pm
Humor often gets misunderstood. I think the whole thing is hilarious. If I said it to your face--which I would any day--you'd know it was humor because I'd be laughing my butt off and so would you.
Date Posted: June-14-2016 at 4:26pm
tryathlete wrote:
Humor often gets misunderstood. I think the whole thing is hilarious. If I said it to your face--which I would any day--you'd know it was humor because I'd be laughing my butt off and so would you. | Sounds good my friend. I don't know why, but I am pretty touchy about the integrity thing which sounds strange after I post all kinds of goofy stuff on here, but when I screw up, I admit it, and if I am further called on it, it makes it seem like I am back peddling, and I do NOT do that. Anyhoo, I apologize for being an internet tough guy. Tom
Date Posted: June-14-2016 at 5:13pm
No worries, Tom. ill be funnier next time I promise.
Date Posted: June-14-2016 at 5:17pm
Date Posted: June-14-2016 at 7:02pm
Hollywood wrote:
Cumalong with the humor | http://s266.photobucket.com/user/turninggrey/media/df11231c686854b8ef973e628ef47772.jpg.html" rel="nofollow">
Posted By: JPASS
Date Posted: June-14-2016 at 8:43pm
^^^^^^LMAO
Posted By: quinner
Date Posted: June-15-2016 at 9:43am
numchuck that numskull numnutz
Date Posted: June-15-2016 at 10:49am
I'll rip those numchucks out of your hands so fast and have one end in you and the other in quinner before you even realize
Date Posted: June-15-2016 at 5:09pm
Hollywood wrote:
I'll rip those numchucks out of your hands so fast and have one end in you and the other in quinner before you even realize | Then you would use us like Clackers https://www.youtube.com/watch?v=FLHftISLNHE" rel="nofollow - Clackers
Date Posted: June-15-2016 at 9:34pm
God that brings back some memories.
