PCM Ford electronic distributor installation instr
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40131
Printed Date: April-29-2024 at 2:13am
Topic: PCM Ford electronic distributor installation instr
Posted By: Cheiz
Subject: PCM Ford electronic distributor installation instr
Date Posted: October-29-2016 at 7:39pm
Newbie question does anyone have a wiring diagram and installation instructions for the PCM Ford electronic distributor retro kit
------------- 93 CC Nautique Excel CB 351 GT40
Posted By: KENO
Date Posted: October-29-2016 at 8:47pm
Look at this http://www.correctcraftfan.com/forum/forum_posts.asp?TID=11544" rel="nofollow - old thread
It may help, it may confuse you more
You can also look at the Discount Inboard Marine website and check out item #41015 which is the conversion kit they sell and there is a wiring diagram better than their hand drawn one in the link above.
This all assumes you now have a Mallory electronic distributor like the one in their kit If not, it would be good to know what you have for a distributor and if you have the whole kit
Posted By: Cheiz
Date Posted: October-29-2016 at 11:31pm
Having trouble getting the distributor in Nautiqueparts Engine Parts > Electrical Parts > Electronic Conversion Kits > Electronic conversion kit for PCM FORD Left Hand Rotation Pro-Tec Motors, PCM # RK107025A ELECTRONIC CONVERSION KIT FOR PCM FORD LEFT HAND ROTATION PRO-TEC MOTORS, PCM # RK107025A
Posted By: KENO
Date Posted: October-30-2016 at 2:23am
Read this old thread about which direction your engine might or might not rotate http://www.correctcraftfan.com/forum/forum_posts.asp?TID=33303&title=91-excel-reverse-rotation-engine" rel="nofollow - old thread it'll probably confuse you but you have a distributor for a LH rotation engine going by what you posted from White Lake Marine and your engine might be RH rotation as you can see from the link above
The best thing you can do is see if your new distributor gear and old one match or if the teeth are cut in opposite directions.
LH teeth look like /////// RH teeth are the opposite \\\\\\
If they're different, you'll need a distributor gear for a RH engine, if they're the same it looks like you're just having trouble getting the gears to mesh
Posted By: Duane in Indy
Date Posted: October-30-2016 at 7:37am
Like KENO said, sounds like you need the one on the right
Posted By: Cheiz
Date Posted: October-31-2016 at 10:15am
Thanks all, looks like you were right, wrong direction distributor. Guess I have to get this one....right? http://www.nautiqueparts.com/electronicconversionkitforpro-tecmotors-1.aspx" rel="nofollow - Electronic distributor kit for REVERSE Rotation (Right Hand) Motors. PCM# RK107026A
Date Posted: October-31-2016 at 10:22am
Cheiz wrote:
Thanks all, looks like you were right, wrong direction distributor. Guess I have to get this one....right? http://www.nautiqueparts.com/electronicconversionkitforpro-tecmotors-1.aspx" rel="nofollow - Electronic distributor kit for REVERSE Rotation (Right Hand) Motors. PCM# RK107026A | The distributor is the same. All that's needed is the gear and then a R&R on the gear.
Posted By: Cheiz
Date Posted: October-31-2016 at 10:24am
Here is the picture before I took the Protec out, can it be confirm the rotation from here? Also, does someone have a diagram of which plugs go into the distributor from what cylinders?
FYI, my motor was not starting at all
Date Posted: October-31-2016 at 10:25am
From the other current thread with the same issue:
KENO wrote:
You could also get a distributor with a normal rotation gear and if you have your RH gear, have a machine shop fit it correctly.
That opens the door to more choices like a Pertronix or MSD marine distributor
You could send a PM to "Duane in Indy" who is a retired machinist and ask if he'd do it for you. It wouldn't be the first time he's done this for somebody on the forum |
Posted By: KENO
Date Posted: October-31-2016 at 10:29am
That would be the right one and you wouldn't have to worry about doing gear swaps that can sometimes be not terribly straightforward
Posted By: KENO
Date Posted: October-31-2016 at 10:33am
Just by looking at your old gear, you can confirm it is a reverse rotation engine.
So, yes your engine is reverse rotation.
Do a search here on CCF about distributor installation, do a lot of reading and you'll probably understand how to install it and get the firing order right.
But after the reading, if you have questions, ask away and you'll get help here
Posted By: Cheiz
Date Posted: October-31-2016 at 11:18am
So just sliding the distributor in by rotating the gears on the oil pump/distributor? Once I get the right kit lol
Saw this thread but am looking for a diagram of the distributor cap top with what plugs go to each cylinder. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=39645&KW=distributor+installation&title=dui-distributor-issue" rel="nofollow - DUI Distributor Issue
My other questions (wish I had a picture but don't have access to my boat) but there are (2) yellow/red wires which I assume is going to the neutral safety switch, one is going to the 50 amp break and the other I had to cut off of the old Protec harness. Where do I need to connect this up to? There was also a light blue wire connected to the old Protec harness that unplugged from the harness.
http://www.planetnautique.com/CorrectCraftManuals/1993/93PCM.pdf" rel="nofollow - PCM Owner Engine Manual
Date Posted: October-31-2016 at 11:36am
| Depending on how well versed you are with engine electrics, think about the basics. Here's Tim's wiring diagram that should help:
http://s133.photobucket.com/user/brainard_bucket_bucket/media/enginewiring84.jpg.html" rel="nofollow">
Cheiz wrote:
So just sliding the distributor in by rotating the gears on the oil pump/distributor? Once I get the right kit lol |
Get some one that knows how to install it to help you. Will need timing light also. Easy once you have done it a few times but very frustrating if you have not.
Firing order looking down on dist. cap. CCW rotation 1 8 4 5 6 2 7 3
Posted By: Hollywood
Date Posted: October-31-2016 at 11:37am
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=34338&title=protec-ignition-swap" rel="nofollow - ProTec Ignition Swap
There is no wiring diagram for your spark plug wires. The rotor points at the post of the cylinder on the compression stroke and you follow the wires along with the order.
You should be able to definitively trace those wires to the NSS (by the color you sound correct) and then use the typical 70s/80s wiring diagram TRBenj drew up.
Why are you getting a new carburetor?
Posted By: Cheiz
Date Posted: October-31-2016 at 1:20pm
So confirmation that this is a right hand rotation and I need the following parts (fyi took out the starter and it was filled of gunk/water)?
I have to return the wrong rotation ones to Nautique.
%20" rel="nofollow - http://www.nautiqueparts.com/electronicconversionkitforpro-tecmotors-1.aspx
%20" rel="nofollow - http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx
Posted By: Cheiz
Date Posted: October-31-2016 at 1:26pm
Thanks all, so when I get the distributor in, plug wires go to it like in the picture below
Date Posted: October-31-2016 at 1:32pm
What does your engine tag say? It should have a model number listed.
Posted By: Cheiz
Date Posted: October-31-2016 at 1:49pm
In the engine compartment above, where is it located?
Date Posted: October-31-2016 at 1:59pm
It should be bolted to the intake manifold. I'm not a v-drive protec expert. TRBenj, Air206 or velde99 would know for sure.
Posted By: Cheiz
Date Posted: October-31-2016 at 2:14pm
Any other way to tell? I would assume that the distributor teeth tell the tale?
Posted By: Cheiz
Date Posted: October-31-2016 at 2:50pm
Looks like I am missing this tag but the manifold reads this.
Chris, Several have mentioned getting help. Being honest here, it's starting to sound like having someone with a better understanding of engine ignition systems would be great. Do you have any friends that could come over and help out? We certainly will continue with any information we can give.
Posted By: desertskier
Date Posted: October-31-2016 at 3:04pm
The wiring diagram for your engine is on page 51 of the manual. In order to remove the Pro-tec you should have only needed to disconnect the trigger plug and the EMS connection. The neutral safety switch is wired to the wire harness plug but does not go to either of the Pro-tec parts. I would print out the wiring diagram and then use it to verify what wires you are cutting/disconnecting. It's pretty easy to follow. We can also use the same terminology from the diagram to walk you through it.
Posted By: KENO
Date Posted: October-31-2016 at 3:15pm
%20" rel="nofollow - http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx |
The teeth on your old shaft tell everything you need to know. It's reverse rotation
You bought the correct starter and the wrong distributor.
You have a Reverse rotation engine, you bought a reverse rotation starter.if it's what your link shows...............KEEP IT, it's the right one. If that's not what you bought and you are going to buy that one, then yes buy the one in the link since it's for a reverse rotation engine
You bought a normal rotation distributor.................exchange it for the reverse rotation version you mentioned earlier.
Posted By: KENO
Date Posted: October-31-2016 at 3:37pm
8122pbrainard wrote:
Chris, Several have mentioned getting help. Being honest here, it's starting to sound like having someone with a better understanding of engine ignition systems would be great. Do you have any friends that could come over and help out? We certainly will continue with any information we can give. |
I'm tending to agree with Pete on getting some help BUT make sure it's someone who understands that a 351 like the one in your boat can and does rotate backwards from a normal 351 in an automotive application.
The little diagram you have is good for cylinder locations and firing order, but you need to have #1 at Top Dead Center on the compression stroke and the rotor can be pointed at any tower on the cap. That tower is where #1 is,(you can aim it wherever you want) That's the hard part to understand and try to explain to someone. Then you work counterclockwise around the cap following the reverse rotation firing order. And you'll need a timing light because the initial installation will get you close enough to run it and then use the light to set the timing right.
It's harder to try to explain it, than to actually do it like Duane in Indy mentioned previously
Date Posted: October-31-2016 at 3:38pm
KENO wrote:
That would be the right one and you wouldn't have to worry about doing gear swaps that can sometimes be not terribly straightforward |
So is the gear on the left on a distributor you purchased and the gear on the right out of your protec? The link above says RH but the picture of the distributor has a LH gear on it. I'm assuming they do have a RH gear distributor like the product info says. The fun never ends!
Posted By: KENO
Date Posted: October-31-2016 at 3:41pm
Hollywood wrote:
So is the gear on the left on a distributor you purchased and the gear on the right out of your protec? The link above says RH but the picture of the distributor has a LH gear on it. |
Hollywood, go to post #3 in this thread and you'll see the web address for the distributor he bought. Not a link there but the web address is right there.
Date Posted: October-31-2016 at 3:47pm
So that's what is pictured on the left I assume. The URL says LH. Like you said, the RH item he found should have a RH gear on it (despite the picture) and will drop right in. I think we confirmed a while back all the engines in the v-drive Barefoot & Excels were RH.
Date Posted: October-31-2016 at 3:52pm
Not that it shouldn't eliminate your problem but it sounds like you are just shotgunning parts. Was your engine cranking over? Although, I guess it doesn't really matter at this point.
Posted By: KENO
Date Posted: October-31-2016 at 3:54pm
sounds good to me WLM wording right and picture wrong
Posted By: Cheiz
Date Posted: October-31-2016 at 3:57pm
Right hand rotation it is:
I need this starter than %20" rel="nofollow - http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx
Posted By: KENO
Date Posted: October-31-2016 at 3:59pm
I need this starter than %20" rel="nofollow - http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx |
YES
Posted By: KENO
Date Posted: October-31-2016 at 4:24pm
Cheiz
Check your private message inbox, I sent you something
KenO
Date Posted: October-31-2016 at 5:02pm
Per the following you need a CCW starter: http://www.arcomarine.com/xhtml/Pages%2028-30%20TechTips%20TellYou,%20StarterRotation,DriveGears.pdf" rel="nofollow - ARCO tech tips
Starter PN 70201 is a CCW starter: http://www.arcomarine.com/xhtml/Pages%2031-38%20InBoard%20Starters.pdf" rel="nofollow - ARCO Starters
The starter on the NP website is an ARCO 70201 and is the correct starter.
Posted By: Cheiz
Date Posted: November-06-2016 at 5:11pm
Anyone have pictures of the coil/resistor location mounts from the electronic ignition kit as well as the bracket that goes towards the back where the 50 amp breaker is?
Thanks
Date Posted: November-07-2016 at 11:18am
Lots of pictures here already, try a google search
"coil mount site:correctcraftfan.com/forum"
Posted By: KENO
Date Posted: November-07-2016 at 2:38pm
"coil mount site:correctcraftfan.com/forum" |
That's way too much typing for us old simple minded guys that don't particularly like typing to begin with Hollywood
correctcraftfan coil mount in a Google search gets the same results without quotes or slashes or any of that stuff.
Posted By: Cheiz
Date Posted: November-14-2016 at 11:56am
Thanks all for the help and guidance. I got the boat turned over and winterized it (boo!).
Attached are the actual instructions for the kit from PCM for future reference.
However, I did run into a wire that I need to connect up.
It is near the Vdrive area and the light blue wire goes towards the interior dash and I am trying to find out where this red wire goes to, any thoughts?
Where does the red wire go from this picture?
Date Posted: November-14-2016 at 3:05pm
That is the neutral safety switch. One wire goes to the key switch and one goes to the starter relay.
Date Posted: November-14-2016 at 3:42pm
Chris, I don't feel that's your NSS. The NSS would be on the trans and not the Walters V drive. Someone will be along who knows more about the Walters but I'd say it's the pressure sender for the Walters. The light blue up to the dash would be to the warning light and the red would be the "hot" + to the switch.
Posted By: KENO
Date Posted: November-15-2016 at 8:56am
I get dizzy looking at the picture, but like Pete said, low oil pressure warning light on the dash gets fed from that switch if I'm looking at the picture right
Here's a link to the v drive manual https://www.bakesonline.com/images/MediaLibrary/TransmissionManual_WalterRV10-50.pdf" rel="nofollow - Walters v drive manual
Unfortunately the page with the wiring diagram doesn't seem to be there
Posted By: Cheiz
Date Posted: November-18-2016 at 1:00pm
Thanks Walters V Drive Page 16
Assume that the light blue to the dash and red to ground?
Posted By: KENO
Date Posted: November-18-2016 at 3:41pm
Good job, where'd you find page 16?
Red to ground doesn't seem to pass the "sanity check" though.
Date Posted: November-19-2016 at 12:00am
| Chris, Check to see if the indicator light is wired to ground or +. Just because you found a wiring diagram in the Walter manual, doesn't mean the light was wired that way by CC.
Posted By: GMacLaren
Date Posted: November-19-2016 at 5:04pm
Seems this thread has strayed a bit from its subject.
If still looking for dizzy info, it's possible this might contain some useful info:
http://www.grantmaclaren.com/72skier/engine4/index.html" rel="nofollow - http://www.grantmaclaren.com/72skier/engine4/index.html
-=Grant=-
------------- -=Grant MacLaren=- Retired Expert http://www.grantmaclaren.com/72skier" rel="nofollow - http://www.grantmaclaren.com/72skier
Date Posted: November-19-2016 at 5:53pm
-=Grant=- | Grant, Please review the complete thread. Thanks.
Posted By: Cheiz
Date Posted: November-21-2016 at 9:31am
Thanks all.
I'll do a check this holiday to determine the mystery wires lol.
Page 16 comes directly from Warner, I contacted them and they shot it over to me.
