Car issues
Forum Name: Off Topic
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=40982
Printed Date: April-29-2024 at 5:26am
Topic: Car issues
Posted By: Chevy350
Subject: Car issues
Date Posted: April-30-2017 at 6:37pm
Well with the boat still in storage, nothing fun going on around here. Recently bought a car, it's a 2003 mazdaspeed protege. Had my fun with it for a few months then Thursday it started acting up. The car is grinding pretty bad in every gear. Mostly 1st and reverse. Shifter linkage seems good, bushings seem good. Anyone have any idea? Cars aren't mine and my dad's strong suit.
------------- 1972 Mustang
Posted By: Gary S
Date Posted: April-30-2017 at 7:18pm
Clutch adjustment is what I'd check first. If it's hydraulic the cylinder could be leaking or the linkages at the pedal or at the clutch end could be worn
Posted By: Chevy350
Date Posted: April-30-2017 at 7:43pm
I think the clutch is working correct because the problem happens after I shift into gear, 1st or reverse and most likely 2nd thru 5th. Once in gear when letting out the clutch the force of moving the car causes what seems like the gear shift popping out of gear and only then do I get a grinding of the gears.
Posted By: fgroce
Date Posted: April-30-2017 at 9:40pm
When the car is stopped when you push in the clutch with the engine running and try to put it in gear, does it grind the gears. If so look under the hood next to the brake master cylinder. There may be a smaller version next to it. If so then this is the master cylinder for the clutch. Make sure it is full of Dot 3 brake fluid. May be able to bleed the slave cylinder, if it low on fluid the slave cylinder is probably failing
------------- FGroce 88 Ski Nautique For 28 years Now 2002 Ski Nautique
Posted By: peter1234
Date Posted: May-02-2017 at 9:53pm
its pretty obvious that it is a transmission issue . Not just a clutch issue. At least it is to me when i read what he is saying.
------------- former skylark owner now a formula but I cant let this place go
Posted By: JD ski
Date Posted: May-02-2017 at 10:54pm
peter1234 wrote:
its pretty obvious that it is a transmission issue . Not just a clutch issue. At least it is to me when i read what he is saying. | I agree, do you know the car history. Did a kid have it that abused it? Doing burnouts for all his friends and speed shifting. A Speed 3 is Mazda's hot rod. A youth oriented car. If you know the history this could eliminate the abuse option but it still sounds like a trans issue. The other opinions all sound right on target if the grinding occurred trying to put the car in gear. But when it is in gear and letting the clutch out could be bent or broken shift forks, or something else.
------------- JD ski, slicing, dicing, and shredding since 1981
1999 Air Nautique, GT40 Pro Boss, Trail Rite trailer 1975 Century Resorter
Posted By: Chevy350
Date Posted: May-03-2017 at 10:38am
Well now the car won't even engage, my dad and I were toubleshooting yesterday and still can't come up with anything. Have a little suspicion that it could be the throw out bearing. When sitting in neutral, you can hear a noise that sounds like something is rubbing/grinding. As soon as the clutch is pushed in, it goes away.
Posted By: Dreaming
Date Posted: May-03-2017 at 3:17pm
not the throw out bearing then.... I agree with the others, you have a trans issue. sounds like the input shaft bearing, or something that is common to all of the gears. don't drive it, if that bearing seizes, you'll have a real problem. from your description, it just sounds like it is starting to seize.
Posted By: d4carlon
Date Posted: May-22-2017 at 9:05am
Try to inspect the clutch pedal adjustment also.
Posted By: Chevy350
Date Posted: June-30-2017 at 5:56pm
After letting the car sit for way too long, my dad and I did get the trans out and went through it all. Came up with the differential went out on it. Finally saved up enough money from working and hopefully going to order the part tonight. Anything else I should inspect before ordering it tonight?
Posted By: SNobsessed
Date Posted: June-30-2017 at 9:59pm
If you aren't going to keep it very long, I would throw it back together. Otherwise there is no end to what could be replaced 'while you are in there'.
Date Posted: June-30-2017 at 10:25pm
Justin, Have you looked into just buying a rebuilt transaxle?
Posted By: oldcuda
Date Posted: June-30-2017 at 10:47pm
Sounds like a bearing on either the main or counter shaft. I would just get a used unit and replace it. Or rebuilt if you plan on keeping it a while.
Posted By: greggboy
Date Posted: September-07-2017 at 5:59am
Yes, i think this is transmission issue.
------------- Anthony J Garcia
