Transmission Oil Strainer (Velvet)
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42410
Printed Date: April-28-2024 at 6:37pm
Topic: Transmission Oil Strainer (Velvet)
Posted By: dgabler
Subject: Transmission Oil Strainer (Velvet)
Date Posted: February-15-2018 at 5:09pm
When looking at the manual for the transmission I noticed they referenced checking/cleaning the oil strainer : http://www.correctcraftfan.com/Downloads/Velvet_Service_Manual.pdf (P22 for procedure and 44 for fig 77 )
Now I read the forums here and the recommended procedure is to sucking the fluid out vs draining which implies to me that most if not all do not do this step. Is it worth the extra headache?
Posted By: Duane in Indy
Date Posted: February-15-2018 at 5:24pm
The strainer only gets the big chunks. If you are having no trouble then there should be no debris. Possible that there is not even a strainer in it. Makes a mess getting it out. Kinda your call.
Posted By: dgabler
Date Posted: February-20-2018 at 2:35am
Much thanks for the peace of mind. Fwiw, ended up not pulling it.
