Advice Buying used SAN 220 '07
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42514
Printed Date: April-29-2024 at 10:48am
Topic: Advice Buying used SAN 220 '07
Posted By: matts
Subject: Advice Buying used SAN 220 '07
Date Posted: March-20-2018 at 7:01am
Hi guys,
we consider buying a used SAN 220 2007. What are your thoughts? What are the typical issues with this boat? What can be checked before buying?
Thanks!!
Posted By: quinner
Date Posted: March-20-2018 at 9:56am
You want to look at overall condition of boat, gel shines and not scratched up, is interior intact, not brittle, no tears rips, etc., motor clean, oil clean, does it sound good running, shift in/out of gear smooth. If boat has perfect pass check what hours it shows vs the hour meter. Motor and trans wise no real known issues, the GM powerplants go thru fuel pumps periodically but not something easily checked. Post pictures and we can certainly provide much more input. Good Luck
Posted By: matts
Date Posted: March-25-2018 at 7:17am
had a look at the boat today, attached some pictures if someone is interested. To me everything looks in very good shape, only the prop has some small visible dents.
Posted By: gt40KS
Date Posted: March-25-2018 at 3:17pm
* Prop looks decent but with visible 'dents' may cause an imbalance. If it's just small nicks, you'll probably be OK, just make sure they don't have rough edges or chunks missing. * Give the prop a spin to make sure the shaft spins fairly freely but doesn't have excessive play at the cutlass. * Look for stress cracks around the strut - direct drives and V-drives are susceptible to underwater impacts, more so that I/O's * Exhaust already has the surf pipe installed, so plus if you're into surfing. * Swim platform isn't installed and I didn't see it in the pics so perhaps check mounting hardware for wear or play * Overall you'll want to check out the engine and transmission very thoroughly as I understand drive train parts for these boats may be hard to come by in the Euro region.
As far as problems for this specific model and/or year range others will have to chime in.
------------- JCCI 1995 Ski Nautique GT40
