Faded gelcoat restoration
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=43177
Printed Date: April-19-2024 at 9:25pm
Topic: Faded gelcoat restoration
Posted By: DockDoc
Subject: Faded gelcoat restoration
Date Posted: July-17-2018 at 1:19pm
I assume this is a common question...
Considering a sport nautique that has clearly been neglected, and stored outdoors under a tarp for a year or two. Here's a picture of the gelcoat... it looks totally faded/scratched.
I had an old boat that had red gel, that was in similar condition. I spent a TON of time and effort wet sanding and buffing, and never was able to get it looking good. Ultimately, I painted it (wasn't worth trying to do new gelcoat).
Question is, do you think this is salvageable? Does wet sanding typically do the job on these boats? Or is this a lost cause and would need a full gelcoat restoration?
Posted By: throttle out
Date Posted: July-17-2018 at 1:28pm
The picture is real vague but a good rule of thumb I like to use is get it wet and observe. What it looks like wet is a good indicator of what you can expect out of a gelcoat resto.
------------- 1989 Ski Nautique 2001 351 PCM w/ 1-1.23
Posted By: DockDoc
Date Posted: July-17-2018 at 1:30pm
throttle out wrote:
The picture is real vague but a good rule of thumb I like to use is get it wet and observe. What it looks like wet is a good indicator of what you can expect out of a gelcoat resto. |
Yeah it's all I have, the seller sent me the photo.
The wet and observe thing is interesting, but on my old boat (which was a wellcraft), the red gel looked great when wet, but I never was able to restore it with wetsanding... immediately faded again.
Posted By: Mojo
Date Posted: July-17-2018 at 1:36pm
You can get most any color to come back if done right, even red. Some won't come back to the original color based on the overall condition. Wet sanding and several passes with a wheel is the process... Takes time and patience and the results should be way better then excepted !!! Happy sanding.....
------------- 05' SV211 TE 73' Martinique had:96' SNOB had:76' Nautique had 77 Tique
Date Posted: July-17-2018 at 1:59pm
My boat prior to resto
After resto It can be done. knowing the process and following it strictly will get er done every time!
Posted By: DockDoc
Date Posted: July-17-2018 at 2:01pm
That does look great, but I would think the gelcoat I showed in the picture looks quite a bit worse than yours did... hard to say though I guess. Not sure I want to put that much effort into a boat that's obviously been neglected, may have other issues as well.
Date Posted: July-17-2018 at 2:25pm
Lots of work for sure
Posted By: Gary S
Date Posted: July-17-2018 at 6:35pm
Can't comment on newer boats but click on my avatar and check out the before and after shots of my Mustang. It is alot of work,you would have to get a good deal on it . Surely there are others to look at
Posted By: gun-driver
Date Posted: July-18-2018 at 11:22pm
I saw that same boat it’s roached out lots of work
Posted By: DockDoc
Date Posted: July-18-2018 at 11:27pm
gun-driver wrote:
I saw that same boat it’s roached out lots of work |
You did? Can you verify the make and model and approximate location? I was thinking about driving two hours to see it but I won't if you're saying it's a mess.
Date Posted: July-18-2018 at 11:48pm
I did not see it in person emailed for more pictures that’s all I needed. It looks to be a 99 sport as stated in the ad
Posted By: DockDoc
Date Posted: July-18-2018 at 11:50pm
gun-driver wrote:
I did not see it in person emailed for more pictures that’s all I needed. |
Ok... But convince me it's the same boat, what year? Where is it located?
Date Posted: July-18-2018 at 11:59pm
Not sure why I need to convince you it says ClaytorLake
https://blacksburg.craigslist.org/boa/d/1999-sport-nautique/6583915541.html" rel="nofollow - https://blacksburg.craigslist.org/boa/d/1999-sport-nautique/6583915541.html
Here’s a nice boat for the money and I can vouch for the condition being excellent
http://www.correctcraftfan.com/forsale/details.asp?ID=9793&sort=&pagenum=2" rel="nofollow - http://www.correctcraftfan.com/forsale/details.asp?ID=9793&sort=&pagenum=2
Posted By: DockDoc
Date Posted: July-19-2018 at 12:23am
http://www.correctcraftfan.com/forsale/details.asp?ID=9793&sort=&pagenum=2" rel="nofollow - http://www.correctcraftfan.com/forsale/details.asp?ID=9793&sort=&pagenum=2 |
Could you really tell from the pictures? I also asked for more pics, and got incredibly close up, pretty useless shots. Wondering if there's more there.
Your SN does look nice, but I'm really in the market for something bigger /deeper vee like the BFN / Excel breeds, or a sport / super sport. Open bow is a huge plus too.
Date Posted: July-19-2018 at 8:30am
DockDoc
Could you really tell from the pictures? [/QUOTE wrote:
Notice two shadows and water ring reflection
Posted By: sanoman
Date Posted: July-20-2018 at 7:58am
DockDoc wrote:
That does look great, but I would think the gelcoat I showed in the picture looks quite a bit worse than yours did... hard to say though I guess. Not sure I want to put that much effort into a boat that's obviously been neglected, may have other issues as well. | That's what the gelcoat on my 89 nautique looked like when l bought it.I work around the auto shop bisiness and a painter buddy and l wet sanded and then buffed the boat out.l never would have thought it would look that good. Yours turned out awesome for red gelcoat,but takes a lot of time to get there!
Posted By: Goldcup101
Date Posted: July-20-2018 at 1:49pm
I restored a 97 Ski last year which is a similar colour. Gelcoat was pretty faded and came up really well using techniques and materials suggested by fellow members on the forum.
Posted By: DockDoc
Date Posted: July-20-2018 at 3:17pm
Awesome thanks! Sounds like there is hope for this boat, potentially.
Date Posted: July-20-2018 at 4:18pm
gun-driver wrote:
I saw that same boat it’s roached out lots of work | I never said it couldn't be restored I said it would be a lot of work and for the money it's listed for that's crazy.
Here's my '85 going under transformation
New graphics
Posted By: Gary S
Date Posted: July-20-2018 at 4:23pm
Trouble is if he's starting off at 11900 your not going to be able to get it down enough to make it worthwhile IMOH. Dash looks a mess,interior replacement eats up money fast
Posted By: DockDoc
Date Posted: July-20-2018 at 4:26pm
Gary S wrote:
Trouble is if he's starting off at 11900 your not going to be able to get it down enough to make it worthwhile IMOH. Dash looks a mess,interior replacement eats up money fast |
Probably right. Boat's too far away for me to easily go look at anyway. And I don't have a sweet shop setup like you to do this kind of work.
Date Posted: July-20-2018 at 4:34pm
You don't need a big shop you can do it in you're driveway just harder that way. I wouldn't be surprised if this is the same boat I saw for sale a year or two ago out of DCL Has the MD registration and the cover snaps going down the side (one of the reasons I didn't like it)
Date Posted: July-20-2018 at 4:38pm
Agreed. At that price, it's too much work.
I only paid $3000 for my 97 due to the amount of work it needed. Also had 1800 hours on it so rebuilt the engine as a precaution (though it was in impressively good condition when inspected) . The fact that it had a decent trailer, PP and a brand new transmission sealed it.
I don't fancy repeating all that sanding & buffing though.
Posted By: DockDoc
gun-driver wrote:
You don't need a big shop you can do it in you're driveway just harder that way. I wouldn't be surprised if this is the same boat I saw for sale a year or two ago out of DCL Has the MD registration and the cover snaps going down the side (one of the reasons I didn't like it) |
Yeah been there done that... pretty sure I don't want to do it again.
I bet it is the same boat, I was also wondering why the MD tags. The correct craft world seems to be a small one...
Date Posted: July-20-2018 at 7:53pm
Don't give up as long as you're willing to do the work. Throw a number at him, most he can say is no and sit on the boat for another year.
Date Posted: July-23-2018 at 2:56pm
Did mine in my driveway!!
Posted By: Donald80SN
Date Posted: July-23-2018 at 10:44pm
Some mail box is missing its numbers.
------------- 1980 Ski Nautique SOLD Back to Cypress Gardens 2002 Sport Nautique, GT-40, FCT2, Cover Sports, Tower Bimini, Inc., Wet Sounds Audio System, Star Gazer Wake Edition S. 1968 Ski Nautique, Project.
Date Posted: July-24-2018 at 12:47am
Donald80SN wrote:
Some mail box is missing its numbers. |
Now that's funny
Date Posted: July-26-2018 at 12:22am
Doc, I live up Hwy 16 ( North or Charlotte) in Denver, NC at Lake Norman, There is a boat dealer on Hwy 16 business , downtown Denver, that has a 1993 or so Sport Nautique with potential. It looks a lot better than what you are looking at in this thread. I stopped today to take some photo's and I will post them here for your review. The dealer is as follows:
KTR Motorsports, Inc. 3840 Hwy 16 Business, Denver, NC 28037. 828=312=1743.
They also have a early 70's Ski Tique for over one year. I walked up to a fence and snapped a few photos. I do not know anything about the boat or the price. However, it reminded me of Randy in Ohio who use to hang out on this site and attended some CCFAN events. I always loved his boat. He now hangs out at Winnebago Fan.com . Randy's ex wife was scared to death of bear attack at the Green Lake WS events. Too funny.
Posted By: DockDoc
Date Posted: July-26-2018 at 12:30am
They also have a early 70's Ski Tique for over one year. I walked up to a fence and snapped a few photos. I do not know anything about the boat or the price. However, it reminded me of Randy in Ohio who use to hang out on this site and attended some CCFAN events. I always loved his boat. He now hangs out at Winnebago Fan.com . Randy's ex wife was scared to death of bear attack at the Green Lake WS events. Too funny. |
That would be AMAZING! I would love to see this, please post pics or if you want to e-mail them to me that would be fine too... Mostly interested in the Sport. Thanks!
Date Posted: July-26-2018 at 12:32am
Decent Ramlin Tandem trailer that needs new tires in a bad way. Major dry rot on the tires. They will likely not make the tow back to Charlotte from Denver. Interior looks good but I am not a fan of the white steering wheel but that can be changed or fixed.
[I
I have more photos if you would like me to send them to you. PM me from this site.
Posted By: ScottZ
Date Posted: December-24-2018 at 11:52am
New graphics
I had a boat identical to yours. Where di you het the graphics?
------------- Scott Zuelzke Lake Mitchell , AL 1984 Ski Nautique 1972 Skier
