Overheating 1989 SN
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=46103
Printed Date: April-29-2024 at 9:07am
Topic: Overheating 1989 SN
Posted By: djenns13
Subject: Overheating 1989 SN
Date Posted: August-22-2018 at 10:36pm
So I've replaced the impeller, got a new thermostat, checked the raw water filter, and replaced all the hoses from where the water would pass through the system. I was curious if anyone has experienced similar issues and been able to find a solution. I've hit the engine with an infrared thermometer but it will give low 100s and the temp gauge will hang around at 170 for a little then jump to 180. This is all while in motion, but no tendency to spike when at idle. I tested the thermostat as well and its functioning properly at the 140 degrees its rated for. Let me know. Dan
Posted By: SNobsessed
Date Posted: August-22-2018 at 10:55pm
djenns13 wrote:
I've hit the engine with an infrared thermometer but it will give low 100s and the temp gauge will hang around at 170 for a little then jump to 180. Dan |
Are you saying the IR thermometer indicated 110F?
If so, your engine is not overheating, your gauge is inaccurate.
Someone else on the site had this same problem recently, I believe it was a wiring or ground issue.
Posted By: bb12
Chances are you have the infamous voltage drop/ weak dash ground and you’re not overheating. Run a jumper ground wire from the temp gauge to the negative battery terminal and see what it does.
You will likely need to run a new dash ground to the permanently solve your issue. If you search the forum, there are many threads about this and how to fix the issue.
------------- 1989 Ski Nautique 2001
Posted By: djenns13
Date Posted: August-22-2018 at 11:42pm
Sweet thanks, currently waiting for a replacement trans cooler as the one on the boat appeared to be bent, if that doesn’t fix it I think the wiring is my next area to attack.
Date Posted: August-23-2018 at 6:35am
bb12 wrote:
You will likely need to run a new dash ground to the permanently solve your issue. | And positive feed besides the negative.
