tranny
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4664
Printed Date: May-10-2024 at 6:24am
Topic: tranny
Posted By: tony87nautique
Subject: tranny
Date Posted: August-29-2006 at 10:26pm
Slight knock coming from tranny....and getting boat vibration in reverse.....do i have tranny probs????
Help!!
Thanks,
Anthony
Posted By: jimbo
Date Posted: August-30-2006 at 12:31am
Maybe, but not necasarily. Could be a number of other things.
What kind of shape is the prop in?
Does the knocking go away when you pick up speed?
How old is the engine/tranny?
Has the Damper plate ever been replaced?
How's the shaft alignment?
Posted By: GottaSki
Date Posted: August-30-2006 at 8:43am
Exactly. Can you turn the shaft by hand easily? if not, alignment is way off and needs immediate attention.
A crappy idle will cause knocking too.
River Rat to Mole
Posted By: eric lavine
Date Posted: August-30-2006 at 10:39am
if its only noise and vibration in reverse you may have a tooth out on your planetary, which is a direct result of hitting something or mis-alignment. the planetary is locked and the planetary gears are not turning in forward or nuetral. if you had noise in all ranges and it went away like these guys said,it would be damper related or a mis fire. the dampers job is to soften torsional vibrations which are created on the powerstroke. if you didnt have a damper your trans would last about 10 hours. diesel engines are worse with torsionals. we had a guy that installed a input coupling wrong on a flywheel and the 3" input shaft snapped in half due to torsionals. check your alignment first, if it is out of whack then you know the problem
Posted By: 9360SAN
Date Posted: August-31-2006 at 2:27am
What model your boat? V-drive /direct drive?
------------- Go on wakeboard
Posted By: boat dr
Date Posted: September-03-2006 at 11:05pm
eric i have a noise coming from deep down inside my C/C,dont know what to make of it .it is like some womens voice,you know sweet and low,you being the tranny guru,what does this mean????my take and see if you agree with me on this,it sounds like,I NEED MORE OF YOUR MONEY. is this just my imagination or is this bitch gonna get what little money that my ex did not???? thank you Dear Abby, oh i mean Eric. Signed Broke Boat Doctor
------------- boat dr
Date Posted: September-04-2006 at 10:25am
the best fix for this one is a set of earplugs, you know it will eventually cost you something
Posted By: The Dude
Date Posted: September-04-2006 at 8:26pm
tony, what do you think?
http://www.correctcraftfan.com/diaries/details.asp?ID=717&sort=&pagenum=1&yrstart=1991&yrend=1995 - 95 Sport
