Where do I connect my heater lines? 98 SN - GT40
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47383
Printed Date: April-28-2024 at 6:23pm
Topic: Where do I connect my heater lines? 98 SN - GT40
Posted By: man0seven
Subject: Where do I connect my heater lines? 98 SN - GT40
Date Posted: April-25-2019 at 1:41am
Hey everybody, I need help in figuring out the best place to connect my heater hot water line and the return line. Can someone tell me or better yet, upload pictures? I know that the low idle wye is supposed to be the best way but where do I put it? Thanks in advance.
------------- 2005 Ski Nautique
Posted By: Gary S
Date Posted: April-25-2019 at 2:27am
The Y goes into the raw water intake hose,I put mine in about a foot before the raw water pump just because it was convenient. The other hose goes into a T that is in the intake manifold port near toward approx 4-5 o'clock of the distributor. Right now there is a temperature sender in it that's why you need the T,the sender has to go back in too. When I first got the boat it did not have the Y,that heater hose was threaded into the drain of that U between the circulation pump and the lower thermostat housing. At idle there was zero heat. That Y made all the difference. If no one beats me to it I'll try to find a picture of the manifold T in my 40 tommorow
Posted By: gun-driver
Date Posted: April-25-2019 at 9:26am
It’s a little hard to see but the Tee is just left of the distributor, that is out “to” the heater. The "Y" fitting "OUT" from the heater I put like Gary said below and just left of the crank pulley. Remember that is the return line so make sure the "Y" is oriented the correct way.
https://ibb.co/qRphL55" rel="nofollow">
Date Posted: April-25-2019 at 2:01pm
This is very helpful. Thank you both.
Posted By: Gary S
Date Posted: April-25-2019 at 6:10pm
I think you guy's engines are in the boat backwards.....
Date Posted: April-25-2019 at 6:32pm
nope that's you as$ pushers that are backwards
