Ignition Switch?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47758
Printed Date: April-27-2024 at 2:31pm
Topic: Ignition Switch?
Posted By: winniskier
Subject: Ignition Switch?
Date Posted: July-17-2019 at 8:36am
After my boat sits for a few days, it does not crank on the first try. When the key is turned to start, no clicking or other starter sounds,,just silence while I mutter. On the second try, it starts right up. Early in the season, this would repeat intermittently after I turned off the engine while the skier climbed on board. Recently, it happens only at first start up. I fixed this years ago by replacing the switch. Just curious whether there may be cause other than a bad switch or lose wire.
------------- Jim
Date Posted: July-17-2019 at 8:52am
Jim, I feel you'll need to do some testing to determine where the problem is. The place to start is the start relay (solenoid) by seeing if you are getting the nominal 12 volts at the small S terminal. The problem could be the ignition switch, the NSS (neutral safety switch) or even the relay itself. From you description, I susspect the NSS and that could just be from a cable needing adjustment.
