Alrernator conversion kit from SKIDIM
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47901
Printed Date: April-28-2024 at 3:29am
Topic: Alrernator conversion kit from SKIDIM
Posted By: KCH6209
Subject: Alrernator conversion kit from SKIDIM
Date Posted: August-11-2019 at 12:09pm
Trying to see if any one has done the alternator conversion kit from SKIDIM. I have an 82 SN 2001 and need to replace alternator and voltage regulator. It looks like the kit contains a whole new wiring harness for the motor and a bracket to mount new alternator.
Posted By: KENO
Date Posted: August-11-2019 at 3:56pm
The kit has everything you need except a set of instructions based on what I know based on a conversation with someone who bought the harness to rewire his older engine.
I might be wrong, so you should call SkiDim and check with them
If you're comfortable with wiring it shouldn't be a problem
Posted By: robertbruder
Date Posted: August-19-2019 at 3:57pm
I didn't have to do the full conversion kit for my '88 but I did put in the new alternator part from SkiDim. It seems to be working correctly, I just think I have another issue with power drain. Installing a battery shut off switch next until I can fully trace it out.
------------- Current: 1988 Sierra Supreme Past: 1986 Correct Craft Martinique, 1984 Ski Supreme, 1984 Bare Foot Nautique
Date Posted: August-19-2019 at 4:34pm
robertbruder wrote:
Installing a battery shut off switch next until I can fully trace it out. | Rob, Have you done any parasitic load testing?
Posted By: zwoobah
Date Posted: August-19-2019 at 5:22pm
8122pbrainard wrote:
robertbruder wrote:
Installing a battery shut off switch next until I can fully trace it out. | Rob, Have you done any parasitic load testing? |
...and remember that no battery = no bilge pump
------------- 1968 Mustang 16 - 351W powered
Date Posted: August-19-2019 at 5:37pm
zwoobah wrote:
...and remember that no battery = no bilge pump |
Please explain.
Posted By: zwoobah
Date Posted: August-19-2019 at 7:09pm
If the boat is left in the water with the battery shut off, it will not have a functioning automatic bilge pump.
Posted By: KENO
Date Posted: August-19-2019 at 8:26pm
Zwoob
Don't mind Pete, he's just being his normal self
He'll probably say that the pump could be wired directly to the battery with a little creativity and a fuse and turning a master disconnect off wouldn't affect the bilge pump's operation if wired like that.
I'd just tell him that if you threw the battery overboard, the bilge pump won't work unless you have some real long battery cables
Date Posted: August-19-2019 at 8:41pm
zwoobah wrote:
If the boat is left in the water with the battery shut off, it will not have a functioning automatic bilge pump. | Chris, Thanks or the explanation. Now I'm embarrassed with not understanding what you were saying. I was still thinking about the parasitic load test trying to understand how it would work without a battery!
Date Posted: August-19-2019 at 11:10pm
The main reason I want to install the shut-off switch is for storage. My convertible has one and I shut it off for winter storage with a battery tender connected and it has been the best winter storage battery maintenance of anything I have owned.
Pete, I haven't done any parasitic testing yet. I can say that this has been a problem since I bought the boat in April. The first step was buy a new battery, second step was buy a new alternator, the third step was that the 40 AMP circuit breaker had a loose connection so that was definitely one major issue, so I replaced the circuit breaker and starter solenoid for good measure as well as the wire connecting between them. Also the ring terminal for my main battery needs to be replaced and recrimped (this one is on me).
Chris, my boat is on a lift and I go out after it rains to manually run the bilge so not real worried about auto-bilge.
Ken, why do you need to bypass to run the bilge when I can take my shop vac out to the dock to get any water out of the boat?
Posted By: KENO
Date Posted: August-19-2019 at 11:12pm
robertbruder wrote:
Ken, why do you need to bypass to run the bilge when I can take my shop vac out to the dock to get any water out of the boat? |
So many ways to get the water out of the boat
That shop vac sounds really really convenient and totally safe too if ya' know what I mean
Must be a battery powered shop vac
Date Posted: August-19-2019 at 11:32pm
Just wrap the extension cord plug with duct tape it's an insulator. 🤣
Posted By: DVskier
Date Posted: August-19-2019 at 11:39pm
Why not just pull the drain plug once it’s on the lift to drain?
Date Posted: August-19-2019 at 11:54pm
Manual crank lift, crank rubs against the dock, and 90 percent of the time I don't bother fighting with getting it fully off the water. An electric lift conversion is on the short list. Until then may just have to use my portable air tank and air ratchet to crank it.
Posted By: zwoobah
Date Posted: August-20-2019 at 1:52pm
DVskier wrote:
Why not just pull the drain plug once it’s on the lift to drain? |
If your lift cable breaks and the plug is out, then your boat sinks. This is also why you should clip a line to the bow ring any time the boat is sitting on the lift - don't want it floating away if the lift fails. I lift mine out of the water, pull the plug to drain anything in the bilge, then put the plug back in and put the cover on. Cover and auto bilge keep it almost perfectly dry.
Posted By: DVskier
Date Posted: August-20-2019 at 5:57pm
Of course you should put the plug back in after it drains! I never store my boat with the plug removed.
