85 SN 2001 rough idle, no acceleration after warm.
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=47915
Printed Date: March-29-2024 at 5:32am
Topic: 85 SN 2001 rough idle, no acceleration after warm.
Posted By: ViperSammy
Subject: 85 SN 2001 rough idle, no acceleration after warm.
Date Posted: August-13-2019 at 5:57pm
Hi all! New to the forum, and new to Nautique boats.
I bought an '85 Ski Nautique 2001 with the 351 and I am experiencing some weird issues.
The boat starts and runs great when cold. Good acceleration to full throttle, even though I think my secondaries kick in late. But, after tooling around the lake for a while, going back to idle causes the engine to run rough, and sometimes die. Restarting is hard, but it will restart if you give it enough juice, and then accelerating is tough without pretty much throwing the throttle to about 1/2 open.
It did this the first time I took it out on the water a few weeks ago, and I thought maybe it was just because it was the first run of the season, and maybe had bad gas, or the pickup had done just that and grabbed some gunk from the bottom of the tank. I also considered the coil and replaced that.
Well, as luck would have it, my tank needed repaired. The fill tube weld had broken and when I filled the tank, it overflowed into the bilge. Not cute. So, I took it and had it repaired, no big deal. Before welding it, they flushed the tank and dried it. So, clean tank when they put it back in. Take it out on the lake; same issue.
So, now I am thinking possible vapor lock. Remember, I am new to marine engines, but not a stranger to these old carbureted V-8's. Now I am reading that vapor lock is very rare on boats because of the cooling system, and I can get behind that, but it doesn't help me with my issue.
Any one have any idea what might be going on? I feel like it is probably something simple that I am missing, but I just can't put my finger on it.
I have checked: Coil - it's new plugs - not new, but in good shape rotor and cap - good (It has an electronic ignition conversion, so no points) plug wires - new choke - seems to be ok, may be running a little bit rich, but no black smoke primaries - spit a little bit until I leaned it out a smidge all vacuum hoses appear to be good, I have not put a gauge on the carb yet, but I do have one. fuel lines - look good, no visible damage
I am open to suggestions.
Thanks in advance!
Scott
------------- '85 Ski Nautique
Date Posted: August-13-2019 at 6:13pm
Scott, When the problem starts, take a look down the carb throat to see if it's dumping extra gas in the engine. You having to open up the throttle is a clue to too much gas. The extra throttle allows more air in overcoming a rich fuel mix.
Welcome to CCfan.
BTW, you do not have a Cleveland. It's a Windsor.
Date Posted: August-13-2019 at 6:27pm
Thanks for that Pete. I will look the next time I am on it. I know it was spitting before so I leaned it out a little already. Maybe it needs more.
And, I was told by previous owner it is a Cleveland. I'll research that too.
Thanks,
Scott
Posted By: KENO
Date Posted: August-13-2019 at 6:40pm
Thanks,
Scott |
Skip the research, count the valve cover bolts
6 per valve cover, it's a Windsor
8 per valve cover, it's a Cleveland
Date Posted: August-13-2019 at 6:44pm
Yeah, that's all I meant, really.
I didn't question it before. But, it's good to know so I don't buy incorrect parts.
Aren't the spark plug requirements even different because of the heads?
Scott
Posted By: KENO
Date Posted: August-13-2019 at 6:56pm
if you go to the reference section you'll find an engine manual that should answer most any questions about the engine as far as specs.
Or click on the link below to get there
http://correctcraftfan.com/Downloads/PCM%20Engine%20Owners%20Manual.pdf" rel="nofollow - link
Date Posted: August-13-2019 at 7:23pm
Nice to have that manual! I had a different one, but it wasn't anywhere as thorough.
Scott
Posted By: MourningWood
Date Posted: August-14-2019 at 1:09am
You and Boyce have similar issues....and similar conjecture. One of the first things I'd check if the boat runs crappy after warming is the choke. Is it opening correctly? The second thing that I've encountered most often (personal experience) is a vacuum leak that 'opens' when warmed up. Lastly...the ignition coil. These can all be checked/tested without buying parts.....yet. Just my .02
------------- 1994 Ski Nautique "Riot" 1964 Dunphy X-55 "One 'N Dun"
Date Posted: August-14-2019 at 9:20am
Thanks MourningWood,
I was considering the choke as well. I will check it for proper operation and adjust it.
I have replaced the coil already, I don't think it is that anymore.
Vacuum leaks are such a pain to track down. I know it's a possibility that is an issue. I will try to figure out if that is it. Any suggestions? Any tricks for finding them?
Thanks again,
Scott
Date Posted: August-17-2019 at 10:45am
So, the PCM owners manual that KENO copied the link for says the timing should be 10* BTC, but the info label on the boat itself says 6* BTC. Which is correct? If it was only a degree or so different, I would just split it, but 4 degrees is a fairly big difference.
Also, I know these older engines were made to run on leaded gas, and that is not available anymore. Is there a need to run a lead substitute or anything like that?
And I am at a loss for what this problem is. Last night took it out and noted that the rough running condition comes and goes.
Tuned the idle mixture and checked for vacuum leaks.
On thing I noticed is that when it does run rough, it sort of sounds like it drops a cylinder.
Scott
Date Posted: August-17-2019 at 11:11am
ViperSammy wrote:
Also, I know these older engines were made to run on leaded gas, and that is not available anymore. Is there a need to run a lead substitute or anything like that? Scott | NO. BTW, there isn't a "lead substitute". Snake oil with a very high mark up that marinas love to sell!
Posted By: KENO
Date Posted: August-17-2019 at 11:29am
Scott |
They're both right, it depends on your distributor
In your 85 you probably have a Prestolite with the clip down cap and 6 degrees is right.
In 87 they went to the later screw down cap Prestolite and 10 degrees is right.
Your 85 has no need at all for gas with lead like Pete said in spite of what the manual says.
What's under the distributor cap ? You might be needing a tune up
Posted By: Gary S
Date Posted: August-17-2019 at 12:03pm
8122pbrainard wrote:
BTW, there isn't a "lead substitute". Snake oil with a very high mark up that marinas love to sell! |
Just being devils advocate here What is the basis of your comments? Any documentation
Posted By: KENO
Date Posted: August-17-2019 at 12:26pm
I can dig up some that says Ford put in hardened exhaust seats long before 1985. You probably could too.
I have a 76 engine that's still running that never had a bit of leaded gas put in it since it was new and no exhaust seat issues around 4000 hrs later.
Remember Unleaded Amoco hi test when everybody else was selling leaded stuff?
That's like a whole sheetload of "Pete years"
Posted By: Gary S
Date Posted: August-17-2019 at 12:44pm
Just pulling your legs. I know the answer and results but read this from the horses mouth back in the day,interesting to note they recommended using an additive probably something to do with lawyers and warranties..... Being that Sam's boat is an 85 the discrepancy in the decals must be due to the confusion at the time. Original question and concern-
Reply-
Posted By: KENO
Date Posted: August-17-2019 at 1:14pm
And I thought I saved some stuff
Date Posted: August-17-2019 at 6:38pm
And I've got a 64 and a 54 that have run on no lead for years without issues. The 77 I believe ether had hardened seats originally or they were added at a rebuild before I purchased the Tique.
Now, has everyone forgotten about the original "marine" fuel called White gas?
Posted By: KENO
Date Posted: August-17-2019 at 6:45pm
77 had hardened seats from the factory
I seem to remember the Amoco I mentioned earlier commonly being called "white gas"
I'm sure there were others too
Date Posted: August-18-2019 at 10:56am
Thanks for all of the input on gas and additives.
A little update on the issue that started this...
I may have mentioned this, but I am no longer convinced that this has to do with heat.
We rented a condo on the lake for the weekend which has given me the opportunity to drive the boat more and under different conditions. Yesterday morning we went down to the lake for a ride, and the boat didn't want to stay running and would die when I went into gear. This was what I was experiencing, but until now, only when it had been running for a while. Well, I was able to limp it out into open water, and get it to open up. It runs well at higher RPMs even though my secondaries come in when they feel like it.. When we slowed down for a no wake, it did well, but when we put the tube in the water to have a little fun, it went back to the rough idle thing. We were able to pull the tube, you just have to really throw the throttle forward to get past the rough part.
This is pretty much my last hoorah this summer as I have to go back to work overseas and won't be home again until Dec. My plan is to pull the carb off before I leave and rebuild it when I get back,
So, we shall see.
Scott
Date Posted: August-18-2019 at 11:22am
Here's the problem:
ViperSammy wrote:
we put the tube in the water to have a little fun,. Scott | http://www.correctcraftfan.com/forum/forum_posts.asp?TID=14181&KW=get+the+kids&PID=163962&title=get-the-kids-out-on-the-water#163962" rel="nofollow - Here's the solution
Date Posted: August-18-2019 at 9:43pm
That thread is awesome!
This past weekend it was just the adults on the boat, so we did a little tubing, then I taught my buddy how to ski. He loves boats and everything about them, even owns a beautiful Baja, but has never skied. Next time we go out though, he will learn to slalom.
Scott
Date Posted: August-19-2019 at 1:10pm
Ok,
Quick question as I try to make sure this 4160 carb is tuned correctly:
The only place I can see to pull vacuum readings is off or the PCV hose. What kind of pressure readings should I be getting? I was only seeing 15 in/hg the other day, and that seemed low to me...
Thanks! Scott
