Holley inlet fitting
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48718
Printed Date: April-24-2024 at 7:47pm
Topic: Holley inlet fitting
Posted By: gun-driver
Subject: Holley inlet fitting
Date Posted: May-22-2020 at 6:37pm
Does any one know what size thread is on both ends of this inlet fitting? I know the one side is a flared fitting thread but what size and the part that screws into the carb base, what size? TIA https://www.nautiqueparts.com/product/carburetor-fuel-inlet-adapter-pcm-r024025/" rel="nofollow - Inlet fitting
Posted By: KENO
Date Posted: May-22-2020 at 6:54pm
7/8-20 and 5/8-18
Must be price shopping
Posted By: KENO
Date Posted: May-22-2020 at 7:05pm
If you're good you can get three for the price of that NP one
Then again.......................If you're real good you can get 4
And..............if you're really really good you can get 5
Posted By: Jonny Quest
Date Posted: May-22-2020 at 7:14pm
How about this one?
https://www.holley.com/products/fuel_systems/carburetor_components/fittings_fuel_lines_and_gauges/fittings/parts/26-26" rel="nofollow - LINK
The Holley / QuickFuel price is $9.00
Date Posted: May-22-2020 at 10:56pm
Actually what I was thinking is... Is there a 90* fitting available That can work in the quick fuel 600 and still use the original solid fuel line.
Posted By: KENO
Date Posted: May-22-2020 at 11:30pm
gun-driver wrote:
Actually what I was thinking is... Is there a 90* fitting available That can work in the quick fuel 600 and still use the original solid fuel line. |
That's a totally different question
Lotsa luck
Date Posted: May-23-2020 at 7:49am
Lotsa luck
| The closest you could get is to use a inverted flare 90.
Date Posted: May-23-2020 at 10:22am
Thanks Pete I was just thinking if you could find a fitting like this in a 9/16 x 9/16 then go with the stock fitting from there.
Date Posted: May-23-2020 at 1:41pm
If you’re trying to save a few dollars, grab a couple Edelmann 821660 and some A1 hose + clamps.
Posted By: Duane in Indy
Date Posted: May-23-2020 at 1:51pm
Pete, That looks like a standard hydraulic hose fitting. That would require hydraulic hose which would also require a similar fitting on the opposite end. They also need to be crimped on by a hydraulic crimp machine. I had a machine to do that with when I had an excavating company but sold it with the equipment, very costly. Guess you could have a hose shop make them for you.
