Horn Troubles
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=48763
Printed Date: May-01-2024 at 3:37am
Topic: Horn Troubles
Posted By: TG3
Subject: Horn Troubles
Date Posted: May-29-2020 at 9:30pm
Hello,
I just bought a 1997 Air Nautique., Great shape, but has. a few things needing some attention.
One is the horn, it won't honk.. When you push the button you can hear it try but its just a hollow buzz sound.
Here is what I did to try to diagnose. Using a voltmeter, I have 12V to the hot side of the horn button. When I press the button, I have around 9 volts coming out. I pulled the horns out (what a pain) and they work when jumpered straight from the battery. I reinstalled the horns, and jumpered 12v from the battery to the wire going to the horn from back of the button (it was unplugged from the button) to rule out the wiring loom. Horns worked with that jumper. I then jumpered from the hot wire at the horn button to the wire going to the horns, bypassing the button all together. The horns worked.
This made me believe it must be the switch. Ordered new switch from Nautique Parts.com and when I installed it, I have the same problem. I checked voltage at the new button and same output, around 9 volts.
So what else could it be? Could the horns actually be bad, needing a full hot load of 12 volts to work, when they should only require the 9 volts I'm getting out of the switch?
Thanks for the help!!
Posted By: TG3
Date Posted: May-30-2020 at 10:43pm
Some additional information:
We went out today and when the boat is running the horn works fine. It also worked ok for a few minutes after we shut the boat off, but after about 10 minutes, it did not.
I'm leaning towards horn is bad after all, and maybe while it was running it was able to get a few more volts, which overcame its bad internals?
------------- 1997 Air/Sport Nautique
Date Posted: May-31-2020 at 9:59am
Trey, I wouldn't condemn the horn just yet. It works when you hooked it up directly to the battery. I think you're loosing the volts someplace due to high resistance. The resistance could be coming from bad connections or even bad contacts in a relay. Set your VOM to Ohms and do some more testing.
Posted By: TG3
Date Posted: May-31-2020 at 4:41pm
8122pbrainard wrote:
Trey, I wouldn't condemn the horn just yet. It works when you hooked it up directly to the battery. I think you're loosing the volts someplace due to high resistance. The resistance could be coming from bad connections or even bad contacts in a relay. Set your VOM to Ohms and do some more testing. |
I'm still learning how to use the VOM.. So if I am getting the full voltage at the hot side of the button, would the first resistance check be to test the wire from the button to the horns? What kind of resistance number should I be looking for? There should be some by nature of the length of the wire, right? But how do I know if there is too much?
Date Posted: May-31-2020 at 5:57pm
Trey, If you are seeing good voltage on one side (in) of ether a switch contact or say a relay contact, but poor volts on the other side (out) then there is resistance dropping the volts. You remove at least one wire from the switch or relay so you are only measuring resistance across it's contact and not resistance from wire or another device. Across the contact, you should read near zero Ohms.
Is the horn button the only switch for the horn? Sometimes there's a relay to handle the higher amps of the horn because the switch can't handle the amps.
Give it a try and I know you will find the VOM to be a very useful tool.
