Q and A
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=5214
Printed Date: April-28-2024 at 5:24am
Topic: Q and A
Posted By: eric lavine
Subject: Q and A
Date Posted: November-14-2006 at 9:52am
just thought I would liven the forum up since the boating season is almost over. went on a warranty call a few years ago, the complaint was the engine was locked up, questioned them thru and thru and here is what they said: you sold us these transmissions which were Twin Disc Mg-540's 5500lbs. each about $85000.00 each. we installed them welded all the brackets and all of the bed rails in place and aligned. on start up the starter just clicked and clicked, changed starters and problem was still there. the engine would not turn... what was the problem
Posted By: quinner
Date Posted: November-14-2006 at 9:59am
The problem was It wasn't a Nautique!
Posted By: DrCC
Date Posted: November-14-2006 at 10:04am
Date Posted: November-14-2006 at 10:08am
another hint: it had something to do with electricity. not a battery or a solenoid either. and the problem was not engine related
Date Posted: November-14-2006 at 10:17am
Id say neutral switch, but I dont think the starter would click.
Posted By: M3Fan
Date Posted: November-14-2006 at 10:29am
I'm a$$uming this is some sort of yacht- perhaps someone was cooking a turkey in the electric oven (visions of that Simpson's episode with Flander's RV come to mind).
Date Posted: November-14-2006 at 10:30am
tugboat, also it was something the customer did
Posted By: Waterdog
Date Posted: November-14-2006 at 10:50am
Painted before attaching the ground.
Posted By: emccallum
Date Posted: November-14-2006 at 11:10am
They welded the drive shaft to something?
Posted By: PLBC
bad ground?
fried computer while welding?
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5164&sort=&pagenum=1" rel="nofollow - 99
Posted By: Nautique2001
Date Posted: November-14-2006 at 11:27am
Califratic Responder?
Furmus Gapper?
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1052&sort=&pagenum=4&yrstart=1986&yrend=1990" rel="nofollow - Nautique 2001
Posted By: MaddMarxx
Date Posted: November-14-2006 at 11:47am
The shore power was still pluged in
Posted By: The Dude
Date Posted: November-14-2006 at 11:52am
I'm going with MM...shore power.
http://www.correctcraftfan.com/diaries/details.asp?ID=717&sort=&pagenum=1&yrstart=1991&yrend=1995 - 95 Sport
Posted By: boat dr
Date Posted: November-14-2006 at 12:09pm
Eric, the KEY WORD, i think is ,welded all the brackets and the bed rails in place.If the ground is installed (welding lead) in the wrong place,engine, tranny or anything with a rubber mount,the welding machine will find a path to ground.engine bearing,roller bearings do not like this........
the other senario, weld everything ; i repeat weld it good,dont spare the rods,
weld it good ...... boat dr
------------- boat dr
Posted By: M3Fan
Date Posted: November-14-2006 at 12:18pm
Don't forget, eric specifically mentions that it was something the customer did.
Date Posted: November-14-2006 at 1:07pm
f-in ay boat doc you got it, they welded with the ground clear on the other side of the rails and it jumped the bearings and slightly welded them, you guys figured it quicker than i did,
Posted By: boat dr
Date Posted: November-14-2006 at 1:28pm
Eric;pa$$ing info on this site is a great way to pa$$ time,but how many of us can relate to ;BEEN THERE DONE THAT,WHERE'S MY TEE SHIRT..........
having been in the boating biz for 25 years,i have found out i dont know beans about boats,and as soon as i think i do ,here comes a new twist on an old problem.
youth is wasted on the young
knowledge on the old...........boat dr
Posted By: Munday
Date Posted: November-14-2006 at 9:22pm
Years ago at my uncle's boat shop,They were working on early chris or century had a loose lag on motor mount.Guy flat rates it puts in longer lag.Customer brings it back says he can't get it off trailor,guess were the longer lag came out?Both sides were about 3/4 inch into the bunks....
I saw the welding ground deal on a trailer axle once really hard on wheel bearings.
Nice story Eric
Munday
Date Posted: November-14-2006 at 9:59pm
I like the lag bolt story better, reminds me of that story where the wife unhooked the trailer from the truck and it was still attached to the boat and she could'nt get the boat to go over 5 miles an hour
Posted By: boat dr
Date Posted: November-14-2006 at 10:39pm
VIP open bow 21 feet,5.7 TBI W/IO .....This is a new boat
motor idles a little funny, not the silkey smooth that they have with 2 hrs.
perform PDI,match #'s drive to engine
install correct 21 pitch s/s prop
fill gear lube tank
check engine oil
fill with regular fuel 10 gals.
check link and sync. of control cables
Go to lake for test run and escape for 1 hr.
motor will only turn 3500 rpm's
this is my third boat boat today,all with the same motor,outdrive,prop,one is blue one is red and this one is green.
timing,advance and valve train all working to specs.
What did GM do wrong??????????????boat dr
eric i solved yours now try mine.....
Date Posted: November-15-2006 at 7:20am
Im not up on this stuff and i dont know if they use rev limiters but that would be my guess or you didnt catch that it was a ford motor lol I'll think on the way to work I know the big blocks have rev limiters,
electrical fuel or mechanical?
Posted By: boat dr
Date Posted: November-15-2006 at 8:34am
to narrow the search,it is not related to spark or exhaust,
funny idle,it dont sound right
Date Posted: November-15-2006 at 9:15am
why you messin with me this early?
is is that water cooled fuel pump?
ask me a tranny question
Posted By: boat dr
Date Posted: November-15-2006 at 9:30am
Eric;
this was a real simple one.....
it ain't fuel,electrical,camshaft and related parts working properly.
Idles funny,at top end no power,almost feels like its MISSING,hint hint
Posted By: Munday
Date Posted: November-15-2006 at 9:39am
Red rag in intake under carb in intake
Munday
Date Posted: November-15-2006 at 9:53am
Im terrible at jeopardy
Date Posted: November-15-2006 at 10:20am
You said electrical and spark are working fine, but were the plug wires on the correct firing order? Right spark plugs?
Posted By: boat dr
Date Posted: November-15-2006 at 10:27am
All m/cruiser engines are test run at Stillwater Ok. prior to ship.No red rags,correct plugs,plug wires in order,
missing,Erics KEY word was WELDED,the KEY word is MISSING
Posted By: boat dr
Date Posted: November-15-2006 at 10:36am
Warning;
this is some of those little head aches that boat shops encounter everyday.We dont have a pay check like the rest of you,40 hrs.of labor does not always = a pay check. Sometimes it = A HARD EARNED LESSON,and that will not buy you a loaf of bread,or pay the light bill...........
Ilove to see a boat come down the drive.....
I get paid when they are repaired,properly..
Eric can you relate to this???????????
boat dr...i spent several hours on this one,M/cruiser flat rated a motor exchange.
Date Posted: November-15-2006 at 11:07am
I give, ive spent 2 fricken days on a bad condensor or 2 days on a bad tach feeding back into the coil
electrical is not one of my strong suits
Posted By: PLBC
Date Posted: November-15-2006 at 12:04pm
missing a piston?
definitely taking some odd guesses here
Date Posted: November-15-2006 at 12:15pm
Tachometer causing issues with engine?
Posted By: boat dr
Date Posted: November-15-2006 at 12:16pm
Ran a compression test on all cyl. #1 thru #7 all 175 lbs. # 8 hardest one to get to,ZERO let me repeat 0000000.what was wrong with this picture????? removed the head,no rod no rings no piston,good reason to be down on power,and that explains the Funny idle...............boat dr
Q C guy had a bad night i guess
Posted By: M3Fan
Date Posted: November-15-2006 at 12:18pm
Must be the advance. Missing the vaccuum hose if it is a vac advance, missing the weights if mechanical?
EDIT - Posted too late. I figured since the engine was tested prior to ship it wouldn't be something like a piston.
Date Posted: November-15-2006 at 12:22pm
Kurt, you were basically right. Nice job!
Posted By: boat dr
Date Posted: November-15-2006 at 12:24pm
PLBC, you win the door prize,that one cost me in frustration and time.Send me your cell # and will call you on the next " problem child " that rolls down the drive.......
move to the front of the line Kurt F
Posted By: p/allen
Date Posted: November-16-2006 at 10:21pm
How was there any oil presure without a rod holding in the oil?
Pat
------------- Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Posted By: 81nautique
Date Posted: November-16-2006 at 10:32pm
Wouldn't it be pushing oil out the exhaust valve.
Sounds like a tall tale there Doc, I'm not a believer yet. How the heck does that get test run and pa$$.
Posted By: boat dr
Date Posted: November-16-2006 at 11:25pm
P/allen was holding good oil pressure,low press.buzzer was not on at idle either. oil flow to the rod is the last place it goes.
81,that statement to me dont make sense,no piston,no suck,no piston no blow.
what would push the oil out the valve.splash would be an issue but there was no oil slick in the water,nor in the y pipe while doing the repower.
how did it pa$$ the test run,ask Stillwater,they did not ask for the core all they wanted was the shipping container..........go figure........boat dr
Date Posted: November-16-2006 at 11:31pm
Doc,
It wasn't a statement it was a question, guess the whole thing just sounds a little hard to believe but I'm not calling you a liar.
Posted By: p/allen
Date Posted: November-16-2006 at 11:32pm
Once had an asphalt paver that had a 4 cyl continental. It was running bad and couldnt figure it out we were doing tests and had the distributor cap off and it ran on 2 cylinders we also ran it on 2 cylinders with the cap on and the rotor out . Couldnt figure out why . Any suggestions?
Pat
------------- Pat
Rock River
Dixon,ILL.
